Low Latency DDR2 800MHz versus 1,066MHz
October 27, 2008 | 07:02
Tags: #5 #3 #4 #800mhz #benchmark #better #cas #ddr2 #p45 #performance #result
Companies: #gskill #intel #test
Paint.NET x64
Website: Paint.NET
This is the 64-bit version of the popular free image editing software, Paint.NET. It's not as advanced as something like Adobe Photoshop CS3 or Corel Paint Shop Pro Photo X2, but it does serve well for most image editing tasks.
We used the PDNBench script to test the processing times for a range of images and filters. The multi-threaded software also takes advantage of multi-core processors quite effectively.
For more information on what the benchmark script entails, please see this thread on the Paint.NET forums.
Paint.NET x64 3.20
PDNBench
  • DDR2 1,066MHz C5
  • G.SKill Pi-Black 4GB 1,015MHz C5
  • G.SKill Pi-Black 4GB 800MHz C4
  • DDR2 800MHz C5
  • 20.7
  • 20.8
  • 20.9
  • 20.9
10
15
20
Time in seconds (lower is better)
Overclocking or performance optimising the memory does little for Paint.NET - merely fractions of a second differentiate the pack.
AutoMKV x264 Encoding
Website: Doom9
We tested x264 compression using AutoMKV version 0.95c and 64-bit x264 encoder to compress a 1.1GB DVD VOB file into 350MB MP4 file using a two-pass encode and we used a 112kbps LAME encoder to compress the audio. The whole process is dependent on both single and multi-core performance and the entire encoding time was recorded.
There's quite a shift to using MKV or MP4 wrappers for x264 content now, especially for movie content and those in the large anime fansubbing community. x264 doesn't have the same SSE enhancements as some other codecs, but the benefits of extra cache and better memory performance should still show notable improvements.
x264 Encoding
AutoMKV 0.95c, 1.05GB MPEG-2 VOB to 350MB .mp4, LAME MT 112Kbps, 64-bit x264
  • DDR2 1,066MHz C5
  • DDR2 800MHz C5
  • 741
  • 742
  • 742
  • 743
200
300
400
500
600
700
800
Again, even video encoding sees very little difference between highly overclocked DDR2 at CAS-5 and latency tweaked DDR2-800MHz CAS-4 - just a second separates them. That second does put the Pi-Blacks ahead, but we could argue it's within experimental error.
