MSI P45 Platinum
June 20, 2008 | 08:21
Tags: #benchmarks #ddr2 #overclocking #p45 #performance #platinum #review
Companies: #intel #msi
Lavalys Everest Memory Performance
Website: Lavalys
Everest Memory Performance Test
  • MSI P45 Platinum
  • Gigabyte GA-EP45-DQ6
  • Asus P5Q Deluxe
  • Gigabyte GA-X48T-DQ6
  • Abit IX38 QuadGT
  • Gigabyte GA-EP35-DS4
  • MSI P35 Diamond
    • 6949
    • 7076
    • 6979
    • 7201
    • 7068
    • 7116
    • 7621
    • 7083
    • 7271
    • 8698
    • 7072
    • 7383
    • 6524
    • 7061
    • 7141
    • 7510
    • 7080
    • 6922
    • 6734
    • 7089
    • 6158
2000
3000
4000
5000
6000
7000
8000
9000
MB/s (higher is better)
  • Load
  • Idle
  • Copy
Everest Memory Latency Test
  • Asus P5Q Deluxe
  • MSI P35 Diamond
  • Abit IX38 QuadGT
  • MSI P45 Platinum
  • 59.4
  • 66.0
  • 66.2
  • 67.3
  • 69.5
  • 72.0
  • 75.3
20
30
40
50
60
70
80
Nanoseconds (lower is better)
The raw memory performance is pretty abysmal compared to other P45 boards. At only 4-4-4-12-2T with no other optimisations it doesn't even fare particularly well against some P35 boards when it comes to write performance. Copy performance is also a bit of a letdown too. The high latency doesn't help matters either – it's nearly 10ns or 14 percent off the optimal performance delivered by the Asus P5Q Deluxe.
SiSoftware Sandra Lite XII.2008.SP2c (14.24)
Website: Sisoftware
Sisoft Sandra Unbuffered Memory Test
  • Asus P5Q Deluxe
  • Abit IX38 QuadGT
  • MSI P45 Platinum
  • MSI P35 Diamond
  • 7525.3
  • 7159.0
  • 6941.7
  • 6770.3
  • 6692.0
  • 6650.0
  • 6053.2
2000
3000
4000
5000
6000
7000
8000
Sisoft Sandra Random Memory Latency Test
  • Asus P5Q Deluxe
  • MSI P35 Diamond
  • Abit IX38 QuadGT
  • MSI P45 Platinum
  • 70
  • 78
  • 80
  • 83
  • 84
  • 87
  • 89
20
30
40
50
60
70
80
90
Sisoft Sandra tells of much the same story – the MSI P45 Platinum's performance doesn't speak of "next generation" at all.
