Lavalys Everest Memory Performance
Website: Lavalys
Everest Memory Performance Test
Sorted by Descending Memory Read Results
  • Athlon X2 6400+ (2x3.2GHz, 1.0GHz HTT)
  • Athlon X2 6000+ (2x3.0GHz, 1.0GHz HTT)
  • AMD Phenom X3 8750 Overclock (3x3.0GHz 3.0GHz HTT)
  • Phenom X4 9850 (4x2.5GHz, 2.0GHz HTT)
  • AMD Phenom X3 8750 (3x2.4GHz 1.8GHz HTT)
  • Phenom X4 9750 (4x2.4GHz, 1.8GHz HTT)
  • Phenom X4 9550 (4x2.2GHz, 1.8GHz HTT)
  • Core 2 Duo E8500 (2x3.16GHz, 1,333MHz FSB)
  • Core 2 Duo E6850 (2x3.0GHz, 1,333MHz FSB)
  • Core 2 Duo E8400 (2x3.0GHz, 1,333MHz FSB)
  • Core 2 Duo E6750 (2x2.66GHz, 1,333MHz FSB)
  • Core 2 Duo E8200 (2x2.66GHz, 1,333MHz FSB)
  • Core 2 Duo E6550 (2x2.33GHz, 1,333MHz FSB)
  • Core 2 Quad Q6700 (4x2.67GHz, 1,066MHz FSB)
  • Phenom 9600 (4x2.3GHz, 1.8GHz HTT)
  • Core 2 Quad Q6600 (4x2.40GHz, 1,066MHz FSB)
  • Phenom 9500 (4x2.2GHz, 1.8GHz HTT)
  • Core 2 Duo E4500 (2x2.20GHz, 800MHz FSB)
    • 9371
    • 9211
    • 8968
    • 8772
    • 8626
    • 8455
    • 8105
    • 5077
    • 8644
    • 8094
    • 5036
    • 8482
    • 7708
    • 4549
    • 7703
    • 7539
    • 4483
    • 7572
    • 7452
    • 4503
    • 7517
    • 7379
    • 7065
    • 7163
    • 7361
    • 6080
    • 6712
    • 7327
    • 7091
    • 7151
    • 7293
    • 6076
    • 6718
    • 7240
    • 7088
    • 7174
    • 7157
    • 6066
    • 6742
    • 6930
    • 4862
    • 5529
    • 6809
    • 4535
    • 7331
    • 6784
    • 4873
    • 5536
    • 6726
    • 4509
    • 7197
    • 5845
    • 3635
    • 4206
5000
7500
10000
MB/s
  • Read (MB/s)
  • Write (MB/s)
  • Copy (MB/s)
Everest Memory Latency Test
  • 44.1
  • 46.4
  • 54.5
  • 54.8
  • 57.4
  • 57.5
  • 58.1
  • 64.8
  • 65.6
  • 67.7
  • 68.1
  • 68.3
  • 68.5
  • 69.4
  • 70.5
  • 70.6
  • 71.9
  • 77.1
20
30
40
50
60
70
80
nanoseconds (lower is better)
Memory performance on the X3 8750 remains consistent with current B3-stepping Phenom X4 processors – in particular, it follows the similarly clocked 9750’s performance characteristics very closely, which doesn’t at all surprise us. What does surprise us though is that it is every-so-slightly faster than the quad-core Phenom X4 9750. Write speeds are of course a bit limited on all of the Phenoms at the moment, but that’s because Everest only loads the one core.
