Lavalys Everest Memory Performance
Website: Lavalys
Everest Memory Performance Test
Sorted by Descending Memory Read Results
  • Athlon X2 6400+ (2x3.2GHz, 1.0GHz HTT)
  • Athlon X2 6000+ (2x3.0GHz, 1.0GHz HTT)
  • Phenom X4 9850 (4x2.5GHz, 2.0GHz HTT: Red Turbo Mode)
  • Phenom X4 9850 (4x2.5GHz, 2.0GHz HTT: Yellow Turbo Mode)
  • Phenom X4 9750 (4x2.4GHz, 1.8GHz HTT: Red Turbo Mode)
  • Phenom X4 9550 (4x2.2GHz, 1.8GHz HTT: Red Turbo Mode)
  • Core 2 Duo E8500 (2x3.16GHz, 1,333MHz FSB)
  • Core 2 Duo E6850 (2x3.0GHz, 1,333MHz FSB)
  • Core 2 Duo E8400 (2x3.0GHz, 1,333MHz FSB)
  • Core 2 Duo E6750 (2x2.66GHz, 1,333MHz FSB)
  • Core 2 Duo E8200 (2x2.66GHz, 1,333MHz FSB)
  • Core 2 Duo E6550 (2x2.33GHz, 1,333MHz FSB)
  • Core 2 Quad Q6700 (4x2.67GHz, 1,066MHz FSB)
  • Phenom 9600 (4x2.3GHz, 1.8GHz HTT)
  • Core 2 Quad Q6600 (4x2.40GHz, 1,066MHz FSB)
  • Phenom 9500 (4x2.2GHz, 1.8GHz HTT)
  • Core 2 Duo E4500 (2x2.20GHz, 800MHz FSB)
    • 9371
    • 9211
    • 8968
    • 8772
    • 8626
    • 8455
    • 8094
    • 5036
    • 8482
    • 8059
    • 5030
    • 8489
    • 7539
    • 4483
    • 7572
    • 7452
    • 4503
    • 7517
    • 7379
    • 7065
    • 7163
    • 7361
    • 6080
    • 6712
    • 7327
    • 7091
    • 7151
    • 7293
    • 6076
    • 6718
    • 7240
    • 7088
    • 7174
    • 7157
    • 6066
    • 6742
    • 6930
    • 4862
    • 5529
    • 6809
    • 4535
    • 7331
    • 6784
    • 4873
    • 5536
    • 6726
    • 4509
    • 7197
    • 5845
    • 3635
    • 4206
5000
7500
10000
MB/s
  • Read (MB/s)
  • Write (MB/s)
  • Copy (MB/s)
Everest Memory Latency Test
  • 44.1
  • 46.4
  • 54.8
  • 54.8
  • 57.5
  • 58.1
  • 64.8
  • 65.6
  • 67.7
  • 68.1
  • 68.3
  • 68.5
  • 69.4
  • 70.5
  • 70.6
  • 71.9
  • 77.1
20
30
40
50
60
70
80
nanoseconds (lower is better)
The memory performance is greatly improved in the B3 Phenoms – with not only lower latencies but faster read, write and copy speeds. The write speeds are still "limited" but Everest does only load one out of four cores. The yellow turbo mode is virtually identical to the red turbo mode – there's very little memory performance and there is no latency difference.
Shopping
