Memory Performance
Crucial Ballistix Tracer Red 4GB PC-6400 (800MHz EPP)
Crucial Ballistix Tracer Red 4GB PC-6400 (1,142Mhz OC)
Corsair TwinX4096-6400C5DHX G (800MHz EPP)
Corsair TwinX4096-6400C5DHX G (1,083MHz OC)
2000
3000
4000
5000
6000
7000
8000
9000
MB/s
Read (MB/s)
Write (MB/s)
Copy (MB/s)
While the memory write performance remains consistent throughout, the read performance grows a few hundred MB/s for both the Crucial and Corsair. What's interesting is that the Corsair running at an overclocked 1,083MHz 5-5-5-15 virtually matches the synthetic memory performance of the Crucial at 800MHz 4-4-4-12. The synthetic copy performance is quite similar between the Crucial and Corsair and increases to a similar level respectively when overclocked.
Crucial Ballistix Tracer Red 4GB PC-6400 (1,142MHz OC)
Corsair TwinX4096-6400C5DHX (800MHz SDP)
nanoseconds (lower is better)
As expected the Crucial at 4-4-4-12 has a lower latency than the Corsair at 5-5-5-18 when both are running at 800MHz, and when overclocked to the same 5-5-5-16 latency, the Crucial's faster clock means again a lower latency.
5814.8
6196.5
5687.3
6136.5
2000
3000
4000
5000
6000
MB/s
20
30
40
50
60
70
80
90
Sisoft Sandra tells a very similar story to Everest – the overclocked Crucial gets the best results and its faster memory timings at 800MHz ekes out just a bit more performance than the Corsair.
