Memory Performance:
Everest Memory Read Test
  • Core 2 Extreme QX9770 (4x3.20GHz, 1600MHz FSB)
  • Core 2 Extreme QX9650 (4x3.00GHz, 1333MHz FSB)
  • Athlon 64 X2 6400+ (2x3.20GHz, 2.0GHz HTT)
  • Core 2 Duo E6850 (2x3.00GHz, 1333MHz FSB)
  • Core 2 Extreme QX6850 (4x3.00GHz, 1333MHz FSB)
  • Core 2 Duo E6750 (2x2.67GHz, 1333MHz FSB)
  • Athlon 64 X2 6000+ (2x3.00GHz, 2.0GHz HTT)
  • Core 2 Quad Q6700 (4x2.67GHz, 1066MHz FSB)
  • Core 2 Quad Q6600 (4x2.40GHz, 1066MHz FSB)
  • 10151
  • 9682
  • 9170
  • 9109
  • 9096
  • 8980
  • 8637
  • 7585
  • 7450
5000
7500
10000
MB/s
Everest Memory Write Test
  • 9067
  • 8516
  • 8401
  • 7120
  • 6095
  • 6094
  • 6086
  • 4877
  • 4866
5000
7500
10000
MB/s
Everest Memory Copy Test
  • 8778
  • 8718
  • 8664
  • 8041
  • 6895
  • 6890
  • 6881
  • 5575
  • 5566
2000
3000
4000
5000
6000
7000
8000
9000
MB/s
Everest Memory Latency
Everest Ultimate Edition
  • 45.3
  • 47.8
  • 50.6
  • 55.0
  • 55.1
  • 55.7
  • 56.4
  • 63.9
  • 65.0
20
30
40
50
60
70
nanoseconds (lower is better)
Intel has needed to use DDR3 at 1,600MHz to catch up with AMD's memory throughput on the Athlon 64 X2, but according to Everest, even Intel still can't match AMD's last generation memory write speed. It's not a huge issue though - the Core 2 architecture is designed to hide this and the massive cache makes the need for fast memory access much less than AMD's CPUs.
Even then, the latency of the Intel setup at 1,600MHz FSB and memory bus is very nearly matching that of AMD's architecture - it just makes you wonder what kind of performance boost will arrive when Intel drops the external MCH for an internal one in Nehalem.
Unbuffered Memory Performance
Sisoft Sandra Unbuffered Memory Test
  • Phenom 9900 (4x2.6GHz, 2.0GHz HTT)
  • Phenom 9700 (4x2.4GHz, 2.0GHz HTT)
  • Athlon 64 X2 6000+ (2x3.00GHz, 1.0GHz HTT)
  • 11211.0
  • 11200.0
  • 8890.7
  • 7589.0
  • 7003.5
  • 6986.0
  • 6975.5
  • 6853.5
  • 5643.0
  • 5626.0
5000
7500
10000
12500
MB/s
Memory Latency
Sisoft Sandra Random Memory Latency Test
  • 61
  • 67
  • 68
  • 70
  • 71
  • 71
  • 81
  • 82
  • 87
  • 87
20
30
40
50
60
70
80
90
Sandra tells much the same story, although Intel comes out both better (latency) and worse (throughput) in this case. The jump from QX9650 to QX9770 is quite considerable though, more so than from QX6850 to QX9650.
Shopping
Stats: 0.017 seconds
