Intel Core 2 refresh: QX6850, E6850 & E6750
Written by Tim Smalley
July 17, 2007 | 09:28
Tags: #2 #computing #core #dual #dual-core #duo #e6750 #e6850 #evaluation #extreme #performance #pricing #quad #quad-core #qx6850 #refresh #review #specs #trusted
Companies: #intel
The Elder Scrolls IV: Oblivion
We used the latest addition to the impressive Elder Scrolls series of titles, Elder Scrolls IV: Oblivion with the 1.2 patch applied. It uses the Gamebyro engine and features DirectX 9.0 shaders, the Havok physics engine and Bethesda use SpeedTree for rendering the trees.
The world is made up of trees, stunning landscapes, lush grass and features High Dynamic Range (HDR) lighting and soft shadowing. If you want to learn more about The Elder Scrolls IV: Oblivion, we recommend giving our graphics and gameplay review a read.
The graphics options are hugely comprehensive, with four screens of options available for you to tweak to your heart's content. There is also the configuration file too, but we've kept things as simple as possible by leaving that in its out of the box state. For our testing, we used a two minute section walking through a wooded area, down into a valley. This test scenario features lots of vegetation and trees, and is one of the most intense sections we've found in the game. We set all of the in-game details to their maximum settings, but left both anti-aliasing and anisotropic filtering disabled.
1024x768 0xAA 0xAF Maximum Details
  • Core 2 Duo E6850 (2x3.00GHz, 1333MHz FSB, 4MB L2)
  • Core 2 Extreme QX6850 (4x3.00GHz, 1333MHz FSB, 2x4MB L2)
  • Core 2 Extreme X6800 (2x2.93GHz, 1066MHz FSB, 4MB L2)
  • Core 2 Duo E6750 (2x2.66GHz, 1333MHz FSB, 4MB L2)
  • Core 2 Extreme QX6800 (4x2.93GHz, 1066MHz FSB, 2x4MB L2)
  • Core 2 Duo E6700 (2x2.66GHz, 1066MHz FSB, 4MB L2)
  • Core 2 Quad Q6700 (4x2.67GHz, 1066MHz FSB, 2x4MB L2)
  • Core 2 Duo E6600 (2x2.40GHz, 1066MHz FSB, 4MB L2)
  • Core 2 Quad Q6600 (4x2.40GHz, 1066MHz FSB, 2x4MB L2)
  • Athlon 64 X2 6000+ (2x3.0GHz, 2x1MB L2)
  • Athlon 64 X2 5600+ (2x2.8GHz, 2x1MB L2)
  • Athlon 64 X2 5200+ (2x2.6GHz, 2x1MB L2)
    • 75.2
    • 54.5
    • 74.9
    • 53.0
    • 73.3
    • 53.0
    • 72.8
    • 50.0
    • 71.9
    • 51.0
    • 71.3
    • 49.5
    • 69.4
    • 48.0
    • 65.9
    • 40.0
    • 65.0
    • 42.5
    • 62.9
    • 42.0
    • 59.2
    • 37.0
    • 57.7
    • 35.0
20
30
40
50
60
70
80
Frames Per Second
  • Average
  • Minimum
1600x1200 0xAA 0xAF Maximum Details
    • 57.6
    • 41.0
    • 56.9
    • 41.5
    • 56.8
    • 40.0
    • 56.7
    • 40.5
    • 56.7
    • 41.5
    • 56.6
    • 39.5
    • 56.5
    • 39.0
    • 56.1
    • 40.0
    • 55.8
    • 38.0
    • 55.2
    • 35.0
    • 54.8
    • 34.0
    • 54.5
    • 38.5
20
30
40
50
60
Frames Per Second
  • Average
  • Minimum
At lower resolutions, the E6850 was fractionally the fastest processor in Oblivion, but as the resolution increased the Core 2 Extreme QX6850 managed to stretch its legs and beat out the E6850 by around 1.2 percent at the same clock speed. Further down the performance chart, the E6750 managed to squeeze out a draw with the faster Core 2 Extreme X6800, even despite its 266MHz clock speed deficit; that said, the Core 2 Duo E6700 was only a fraction slower than both of these chips.
AMD's fastest single socket processor was just a few fractions of a frame per second slower than the competition and, really speaking, you're not going to notice any performance differences between these processors in a typical real-world gaming scenario as you'll be graphics limited once you start introducing anti-aliasing and anisotropic filtering into the equation.
