Test Setup
We attempted to keep a consistent CPU speed through testing, however due to limitations in chipset straps between CPU front side bus and memory bus when overclocking, a closest fit was applied where necessary.
Memory Speeds Tested
OCZ DDR2 PC2-6400 SLI-Ready Edition- PC2-800MHz (lowest latency, 3-3-3-8-15-4tWR-2T) 2.93GHz/266MHz FSB;
- PC2-800MHz (EPP rated timings, 4-4-4-15-22-2T) 2.93GHz/266MHz FSB;
- PC2-1156MHz (maximum overclock, 5-5-5-15-32-6tWR-2T) 2.34GHz/267MHz FSB;
OCZ DDR2 PC2-8500 Reaper HPC Edition - PC2-800MHz (lowest latency, 4-4-4-12-22-5tWR-2T) 2.93GHz/266MHz FSB;
- PC2-1066MHz (EPP rated timings, 5-5-5-15-22-5tWR-1T) 2.96GHz/266MHz FSB;
- PC2-1178MHz (maximum overclock, 5-5-5-15-33-6tWR-2T) 2.95GHz/268MHz FSB;
OCZ DDR2 PC2-9200 FlexXLC Edition - PC2-800MHz (lowest latency, 3-3-3-9-18-4tWR-1T) 2.93GHz/266MHz FSB;
- PC2-1151MHz (rated timings, 5-5-5-18-32-5tWR-2T) 295GHz/268MHz FSB;
- PC2-1210MHz (maximum overclock, 5-5-5-15-34-6tWR-2T) 2.60GHz/269MHz FSB;
Kingston HyperX KHX9600D2K2/2G - PC2-800MHz (lowest latency, 3-3-3-8-18-2T) 2.93GHz/266MHz FSB;
- PC2-1200MHz (rated timings, 5-5-5-15-31-2T) 2.93GHz/266MHz FSB;
- PC2-1232MHz (maximum overclock, 5-5-5-15-32-2T) 2.964GHz/270MHz FSB;
Corsair CM2X1024-9136C5D - PC2-800MHz (lowest latency, 3-3-3-6-14-4tWR-2T) 2.93GHz/266MHz FSB;
- PC2-1142MHz (rated timings, 5-5-5-15-30-5tWR-2T) 2.93GHz/266MHz FSB;
- PC2-1200MHz (maximum overclock, 5-5-5-15-33-6tWR-2T) 2.93GHz/266MHz FSB;
Corsair CM2X1024-10000C5D - PC2-800MHz (lowest latency, 3-3-3-6-10-3tWR-2T) 2.93GHz/266MHz FSB;
- PC2-1250MHz (rated timings, 5-5-5-18-15-6tWR-2T) 2.981GHz/271MHz FSB;
Intel Core 2 Extreme X6800 (operating at 2.93GHz - 11x266); Inno3D nForce 680i SLI, Nvidia Geforce 7900GTX; Seagate 7200.9 200GB 7200RPM SATA 3Gbps hard disk drive; OCZ GameXStream 700W power supply unit; Windows XP Professional Service Pack 2; DirectX 9.0c; Nvidia Forceware 94.24 WHQL; Nvidia nForce 680i SLI 9.53 WHQL;
Memory Latency
OCZ DDR2 PC2-6400 SLI-Ready Edition (800MHz Low Latency)
OCZ DDR2 PC2-6400 SLI-Ready Edition (800MHz)
OCZ DDR2 PC2-8500 Reaper HPC Edition (800MHz)
OCZ DDR2 PC2-9200 FlexXLC Edition (800MHz)
Kingston HyperX KHX9600D2K2/2G (800MHz)
Corsair CM2X1024-9136C5D (800MHz)
Corsair CM2X1024-10000C5D (800MHz)
OCZ DDR2 PC2-8500 Reaper HPC Edition (1066MHz)
Corsair CM2X1024-9136C5D (1142MHz)
OCZ DDR2 PC2-9200 FlexXLC Edition (1151MHz)
OCZ DDR2 PC2-6400 SLI-Ready Edition (1156MHz)
OCZ DDR2 PC2-8500 Reaper HPC Edition (1178MHz)
Kingston HyperX KHX9600D2K2/2G (1200MHz)
Corsair CM2X1024-9136C5D (1200MHz)
OCZ DDR2 PC2-9200 FlexXLC Edition (1210MHz)
Kingston HyperX KHX9600D2K2/2G (1232MHz)
Corsair CM2X1024-10000C5D (1250MHz)
72
77
77
67
68
90
90
70
84
70
70
69
67
69
68
68
66
20
30
40
50
60
70
80
90
nanoseconds (lower is better)
59.4
62.0
61.9
55.9
55.7
60.4
60.8
57.4
56.8
57.2
58.0
57.3
56.2
56.6
55.9
56.4
55.6
The 9200 FlexXLC performs appreciably as fast as the 9600 Kingston at 800MHz low latency, with the SLI edition memory only being a fraction slower, even though it's supposed to be only CAS-4 at 800MHz. Using the modules up to the EVP limit means it'll do CAS-3 with ease. The Reaper 8500 unfortunately only does CAS-4 low latency 800MHz and only achieves a modest overclock.
At faster speeds the performance of the OCZ memory is approximately the same as the other memory at similar speeds.
