For our Photoshop Elements test, we used a selection of 400 3MP photographs taken in a variety of surroundings using the batch file processing function in the Elements Editor. We performed all of the auto fixes, including Auto Levels, Auto Contrast, Auto Colour and Sharpen before resizing the image to 640x480 and saving as a high quality JPEG.
Adobe Photoshop Elements
Our Photoshop Elements yielded a healthy seven percent performance increase for the E6750. To put that into perspective, you'll save over 20 seconds of processing time over the course of a batch of 400 three megapixel photographs.
WinRAR - File Compression & Encryption:
Our file compression and decompression tests were split into two halves to cover a broad spectrum of performance. The first test we ran was to compress and encrypt the MPEG-2 source file from our video encoding test with the highest quality compression ratio. Secondly, we compressed and encrypted the folder of 400 photographs used in our Photoshop Elements test with the same compression settings.
There was very little, if any performance difference between the E6750 and E6700 in our WinRAR tests, although the E6700 notched up a first win in the small file decompression test.
