First Look: Corsair CM3X1024-1333C9DHX
Xvid Encoding:
We tested video encoding performance using VirtualDub-MPEG version 1.6.15 and a multi-threaded version of the Xvid codec, along with the LAME MT MP3 encoder for encoding audio. We did a two-pass encode of a 15-minute 276MB digital TV recording with a target file size of 100MB.
Xvid Encoding
VirtualDub MPEG-2 1.6.15, Xvid 1.2 beta, 276MB .mpg to 100MB .avi
  • DDR3-800MHz 5-4-4-8
  • DDR3-1066MHz 7-7-7-15
  • DDR3-1333MHz 9-9-9-24
  • DDR3-1520MHz 9-9-9-24
  • DDR2-800MHz 3-4-4-9
  • DDR2-1066MHz 5-5-4-12
  • 697
  • 689
  • 660
  • 646
  • 685
  • 672
200
300
400
500
600
700
Time in Seconds (lower is better)
DDR3 is finally a winner, with 1333MHz+ out performing DDR2 at both speeds we've tested here. Again, 1066MHz DDR3 isn't really worth considering, you might as well invest in DDR2 at the same clock speed.
MP3 Encoding:
We used LAME MT for our audio encoding test - it's the multi-threaded version of the popular LAME MP3 encoder. We ran tests with both Intel's and Microsoft's compilers - naturally, the Intel compiler resulted in some performance increases on Intel's processors. We converted all 18 tracks from Moby's popular Play album to a 192kbps variable bit-rate MP3.
MP3 Encoding (Intel)
LAME 3.97, Moby - Play, .wav to 192KHz .mp3, Intel Compiler
  • 104
  • 103
  • 100
  • 100
  • 117
  • 99
50
75
100
125
MP3 encoding only benefits slightly from memory bandwidth, and despite the (continuous!) anomalous result, DDR2 and DDR3 perform within just a couple of seconds of each other.
MP3 Decoding
MP3 Decoding (Intel)
LAME 3.97, Moby - Play, .192KHz .mp3 to .wav, Intel Compiler
  • 37
  • 41
  • 38
  • 36
  • 35
  • 30
20
30
40
MP3 decoding is even less memory intensive, and yet again DDR2 out performs even the fastest DDR3.
