Call of Duty 2:
Publisher: Activision
We used the full version of Call of Duty 2, patched to version 1.2. The game makes use of some awesome effects and is generally very graphically intense and immersive. That's helped by the tremendous smoke effect that Infinity Ward have created - it's better than anything we've ever seen before. There are also real time shadows and a subtle HDR lighting effect too.
The gameplay is not as linear as the first version of Call of Duty, and Infinity Ward has ditched the rather old Quake 3 engine in favour of creating its own proprietary graphics engine to render the effects. There is something about the game that makes it very intense and you often find yourself having to take a break from the action because you're too overwhelmed by its immersiveness and intensity.
We used a custom timedemo that covers both indoor and outdoor performance in the title across one of the most intensive portions of the game. The Optimise for SLI option was disabled for single GPU configurations as it causes some texture corruption if there is only one GPU present. It was enabled for dual-GPU configurations and all other options were set to their maximum values.
GeForce 8800 series round-up Call Of Duty 2 GeForce 8800 series round-up Call Of Duty 2
The five cards with less than 512MB of memory tailed off after 1600x1200 2xAA 8xAF because there wasn't enough memory available for the game when set to the highest texture quality settings. In order to get smooth frame rates at higher resolutions on these cards, you're going to have to reduce the texture details somewhat.
The GeForce 8800 GTXs managed to maintain decent frame rates all the way to 2560x1600 2xAA 8xAF, but even at this resolution, there wasn't much of a difference between the standard 8800 GTX and the pre-overclocked cards from EVGA and XFX. ATI's Radeon X1950 XTX kept up with the XFX and BFGTech GeForce 8800 GTSs quite well, and maintained satisfactory frame rates all the way up to 1920x1200 4xAA 8xAF with the maximum in-game details.
