MSI P4N Diamond & Gigabyte GA-8N-SLI
MSI P4N Diamond & Gigabyte GA-8N-SLI High-Detail Gaming Performance
Summary
Our tests are not quite as GPU limited as they could be - if you are looking towards an SLI system, you are most likely going to be looking at running with 4xAA in every every game at 1280x1024. The differences between the two boards are very small when playing at realistic gaming resolutions. The Intel D925XCV is no slouch in real-world gaming either and you would be hard pushed to see the difference between the two chipsets. Unless you are planning to add a second video card, your 925X-based motherboard will perform just fine in real-world gaming scenarios.
