Logitech Z-680 THX 5.1 Speakers
The Logitech Z-680's are definitely at the high-end of the PC audio spectrum. If you decide to acquire some (and I recommend you do) don't be sloppy about it. Speakers of this quality deserve to be installed in the proper way, not just slapped on your desk and various piles of PC mags in the back corner of your room. Because you deserve to have the audio delivered to you properly the way these babies can. And since this setup is on the high end of the available PC offerings out there, so they are a bit pricey, but then aren't all things of high quality?As I said earlier in the review, if you do some research, you can find these for much less online. The best thing I can say about these speakers are that they are worth the money. They take your HTPC and game sound to a whole new level. Logitech did it right with the Z-680 THX 5.1 surround speakers.
Pros:
All around amazing sound quality.
Decoder/Control console unit gives you full control and input options.
Remote Control is a huge plus, especially when using these as a home theatre configuration.
Design of the satellites make them versitile and easy to install.
Cons:
Price (expensive but worth it)
Made the UPS man mad at me, because of their weight, you could pay big money for shipping.
Thanks to Logitech for sending these to us for review.
Logitech Z-680 THX 5.1 Speakers Conclusion
