Colour Accuracy and Gamma
Colour accuracy is determined by displaying a series of different test colours and comparing the displayed value (as measured by the colorimeter) to the expected, ideal value. A complicated formula then outputs what is known as a delta E value, which in simple terms represents how far the displayed colour is from the ideal. Lower values are preferred, since that means the distance is less.
Colour Accuracy
Datacolor Spyder4Elite, max brightness
  • ViewSonic VX2776-smhd
  • AOC G2460PF
    • 0.63
    • 5.71
    • 3.44
    • 8.01
5
6
7
8
Delta E (Lower Is Better)
  • Average
  • Maximum
AOC G2460PF Review AOC G2460PF Review - Colour Accuracy and Gamma
Gamma, meanwhile, refers to how a monitor deals with and corrects for the non-linear relationship between the amount of voltage applied to a pixel and the amount of light emitted. As such, it mainly affects the output of mid-range and greyscale colours. We are looking for a value of 2.2, which is in line with the standard sRGB colour space.
