PCMark Vantage x64
Publisher: Futuremark
PCMark Vantage x64 is a Vista-only 64-bit productivity benchmark that tests a range of standard application types providing a general performance number in respect to other systems.
It tests multi-core processors and requires a processor with at least SSE2 support and a graphics card that supports Shader Model 2.0 or higher.
There are test scenarios for High Definition TV and Movies, Gaming, Memory, Music, Communications, Internet, General Productivity and Hard Drive. They cover the broad range of typical software a PC user will use and acts as a good "one stop" benchmark for general system performance.
PCMark Vantage x64
PCMarks
  • Core i7 920 OC (4x4GHz, 1,600MHz DDR3, 3.6GHz QPI)
  • AMD Phenom X4 9850 OC (4x3GHz, 2.0GHz HTT)
  • Core 2 Duo E8400 OC (2x4.0GHz, 1,760MHz FSB, DDR2)
  • Core 2 Duo E8400 OC (2x4.0GHz, 1,760MHz FSB, DDR3)
  • AMD Phenom X4 9950 BE (4x2.6GHz, 2.0GHz HTT)
  • Core 2 Quad Q6600 OC (4x3.6GHz, 1,600MHz FSB, DDR3)
  • Core 2 Quad Q6600 OC (4x3.6GHz, 1,600MHz FSB, DDR2)
  • Core 2 Duo E8500 (2x3.16GHz, 1,333MHz FSB, DDR3)
  • AMD Phenom X4 9750 (4x2.4GHz, 1.8GHz HTT)
  • AMD Phenom X4 9850 BE (4x2.5GHz, 2.0GHz HTT)
  • Core 2 Duo E8500 (2x3.16GHz, 1,333MHz FSB, DDR2)
  • Core i7 920 (4x2.66GHz, 4.8GHz QPI, SMT enabled)
  • Core 2 Quad Q9550 (4x2.83GHz, 1,333MHz FSB, DDR3)
  • Core 2 Quad Q9550 (4x2.83GHz, 1,333MHz FSB, DDR2)
  • Core 2 Quad Q6700 (4x2.66GHz, 1,066MHz FSB, DDR3)
  • Core i7 940 (4x2.93GHz, 4.8GHz QPI, SMT enabled)
  • Core 2 Quad Q6700 (4x2.66GHz, 1,066MHz FSB, DDR2)
  • Core 2 Quad Q9450 (4x2.66GHz, 1,333MHz FSB, DDR3)
  • Core 2 Quad Q9450 (4x2.66GHz, 1,333MHz FSB, DDR2)
  • Core i7 965 (4x3.2GHz, 6.4GHz QPI, SMT enabled)
  • Core 2 Quad Q9650 (4x3.0GHz, 1,333MHz FSB, DDR3)
  • Core 2 Extreme QX9770 (4x3.2GHz, 1,600MHz FSB, DDR3)
  • Core 2 Quad Q9650 (4x3.0GHz, 1,333MHz FSB, DDR2)
  • Core 2 Extreme QX9770 (4x3.2GHz, 1,600MHz FSB, DDR2)
    • 124.2
    • 118.5
    • 111.9
    • 111.9
    • 110.3
    • 109.4
    • 106.2
    • 100.4
    • 100.0
    • 99.1
    • 92.7
    • 77.0
    • 76.0
    • 74.6
    • 69.4
    • 68.8
    • 67.6
    • 62.8
    • 57.4
    • 56.5
    • 47.0
    • 43.7
    • 40.1
    • 39.5
50
75
100
125
Relative Percentage (Normalised to 100%)
  • Relative CPU Value
PCMark Vantage x64
PCMarks
    • 122.0
    • 116.6
    • 113.8
    • 104.2
    • 102.7
    • 102.5
    • 100.0
    • 91.9
    • 90.7
    • 85.2
    • 83.4
    • 81.1
    • 80.1
    • 79.9
    • 75.0
    • 74.7
    • 71.4
    • 70.9
    • 63.8
    • 61.8
    • 58.9
    • 57.0
    • 53.5
    • 53.3
50
75
100
125
  • Relative Platform Value
In terms of CPU value the overclocked Core i7 920 tops the tables like we've come to expect but the AMD is hot on its heels. When we look at a relative platform : performance comparison though the AMD's win simply because their cheaper motherboard and DDR2 memory means it gives better value.
The Core i7's tend to be negative in PCMark, compared to the baseline performance value, just like most of the Core 2 CPUs - the increase in prices are clearly not reflected in a proportionately more positive overall PCMark score.
