AMD Phenom II X4 940 and 920 CPUs
January 8, 2009 | 05:23
Tags: #2 #45nm #920 #940 #benchmarks #core #cpu #ii #oc #overclock #overclocking #perform #performance #phenom #processor #quad #result #review #soi #testing #x4
Companies: #amd
Paint.NET x64
Website: Paint.NET
This is the 64-bit version of the popular free image editing software, Paint.NET. It's not as advanced as something like Adobe Photoshop CS3 or Corel Paint Shop Pro Photo X2, but it does serve well for most image editing tasks.
We used the PDNBench script to test the processing times for a range of images and filters. The multi-threaded software also takes advantage of multi-core processors quite effectively.
For more information on what the benchmark script entails, please see this thread on the Paint.NET forums.
Paint.NET x64 3.20
PDNBench
  • Core i7 965 (4x3.2GHz, 6.4GHz QPI, SMT enabled)
  • Core i7 940 (4x2.93GHz, 6.4GHz QPI, SMT enabled)
  • Core i7 920 (4x2.66GHz, 6.4GHz QPI, SMT enabled)
  • Core 2 Extreme QX9770 (4x3.2GHz, 1,600MHz FSB, DDR3)
  • Core 2 Extreme QX9770 (4x3.2GHz, 1,600MHz FSB, DDR2)
  • Core 2 Quad Q9650 (4x3.0GHz, 1,333MHz FSB, DDR2)
  • Core 2 Quad Q9650 (4x3.0GHz, 1,333MHz FSB, DDR3)
  • Core 2 Quad Q9550 (4x2.83GHz, 1,333MHz FSB, DDR3)
  • Core 2 Quad Q9550 (4x2.83GHz, 1,333MHz FSB, DDR2)
  • Core 2 Quad Q9450 (4x2.66GHz, 1,333MHz FSB, DDR3)
  • Core 2 Quad Q9450 (4x2.66GHz, 1,333MHz FSB, DDR2)
  • Core 2 Quad Q6700 (4x2.66GHz, 1,066MHz FSB, DDR2)
  • Core 2 Quad Q6700 (4x2.66GHz, 1,066MHz FSB, DDR3)
  • AMD Phenom II X4 940 (4x3.0GHz, 1.8GHz HTT)
  • AMD Phenom II X4 920 (4x2.8GHz, 1.8GHz HTT)
  • AMD Phenom II X4 (4x2.6GHz, 2.0GHz HTT)
  • AMD Phenom X4 9950 BE (4x2.6GHz, 2.0GHz HTT)
  • AMD Phenom X4 9850 BE (4x2.5GHz, 2.0GHz HTT)
  • Core 2 Duo E8500 (2x3.16GHz, 1,333MHz FSB, DDR3)
  • Core 2 Duo E8500 (2x3.16GHz, 1,333MHz FSB, DDR2)
  • AMD Athlon X3 8750 BE (3x2.4GHz, 1.8GHz HTT)
  • AMD Athlon X2 7750 BE (2x2.7GHz, 1.8GHz HTT)
    • 13.6
    • 15.4
    • 16.9
    • 19.8
    • 19.9
    • 20.1
    • 21.1
    • 21.7
    • 22.2
    • 23.3
    • 23.6
    • 24.4
    • 24.8
    • 26.3
    • 28.5
    • 30.1
    • 31.3
    • 32.1
    • 37.3
    • 37.8
    • 43.3
    • 57.7
20
30
40
50
60
Time in Seconds (lower is better)
  • Seconds
The Phenom II CPUs don't fair well in the highly threaded Paint.NET and while several seconds faster than the previous generation, barely even make a dent on the Intel CPUs, with only the dual cores sitting lower down the table. Clock to clock the performance is about a second better - or four percent - while the Phenom X4 9950 is about 19 percent slower than the fastest X4 940 CPU. In the same way though, the X4 940 is just over 11 percent slower than the Intel Core 2 Quad Q9450 with DDR2, which is also cheaper.
AutoMKV x264 Encoding
Website: Doom9
We tested x264 compression using AutoMKV version 0.97.1 and x264 to to compress a 1.1GB DVD VOB file into 350MB MP4 file using a two-pass encode and we used a 112kbps LAME encoder to compress the audio. The whole process is dependent on both single and multi-core performance and the entire encoding time was recorded.
There's quite a shift to using MKV or MP4 wrappers for x264 content now, especially for movie content and those in the large anime fansubbing community. x264 doesn't have the same SSE enhancements as DivX 6.8, but the benefits of extra cache and better memory performance should still show notable improvements.
x264 Encoding
AutoMKV 0.97.1, 1.05GB MPEG-2 VOB to 350MB x264 .mp4, LAME MT 112Kbps
  • Core i7 940 (4x2.93GHz, 4.8GHz QPI, SMT enabled)
  • Core i7 920 (4x2.66GHz, 4.8GHz QPI, SMT enabled)
    • 448
    • 500
    • 545
    • 546
    • 553
    • 580
    • 585
    • 611
    • 611
    • 616
    • 645
    • 651
    • 651
    • 688
    • 690
    • 692
    • 721
    • 747
    • 882
    • 885
    • 942
    • 1161
500
750
1000
1250
  • Seconds
The Phenom II performance is pretty much exactly where we'd expect it to be - the 940 is wedged between the Intel Q9550 DDR3 and DDR2 times (while matching the faster DDR3), and the 920 matches the Q9450. Again, raw core MHz rather than memory controller speed plays a more important role here as the clock to clock 2.6GHz Phenom II versus original Phenom is faster, but way off the pace of the 2.8 and 3.0GHz retail CPUs.
The performance improvement between generations of Phenoms is quite impressive though where clock to clock it's around five percent faster, but X4 940 versus X4 9950 there is an impressive 18 percent difference.
Mod of the Month July 2020 in Association with Corsair
August 7 2020 | 17:30
