AMD Phenom II X4 940 and 920 CPUs
January 8, 2009 | 05:23
Tags: #2 #45nm #920 #940 #benchmarks #core #cpu #ii #oc #overclock #overclocking #perform #performance #phenom #processor #quad #result #review #soi #testing #x4
Companies: #amd
Half-Life 2: Episode Two
Publisher: Valve
As one part of our game of the year 2007, Half-Life 2: Episode Two set a new high in narrative and gameplay for the series. Using Valve's widely used, albeit not overly hardware intensive, Source engine that also features as a part of legendary games like Counter-Strike, Team Fortress 2 and Portal, we were keen to feature its performance here too.
The Source engine is the most scalable engine we test. While it still supports only DirectX 9.0, it features effects like dynamic lighting with HDR effects, motion blur, advanced Havok Physics and high model details.
Episode Two took Half-Life out into large open environments for the first time and we test with Gordon running through a large open level that combines forest and houses with explosions and physics.
All in game detail settings are set to their highest levels, with HDR enabled and, for anti-aliasing, MSAA was used and controlled from inside the game.
1680x1050 4AA 4AF, All High Settings
  • Core i7 965 (4x3.2GHz, 6.4GHz QPI, SMT enabled)
  • Core i7 940 (4x2.93GHz, 4.8GHz QPI, SMT enabled)
  • Core 2 Extreme QX9770 (4x3.2GHz, 1,600MHz FSB, DDR2)
  • Core i7 920 (4x2.66GHz, 4.8GHz QPI, SMT enabled)
  • Core 2 Extreme QX9770 (4x3.2GHz, 1,600MHz FSB, DDR3)
  • AMD Phenom II X4 940 (4x3.0GHz, 1.8GHz HTT)
  • Core 2 Quad Q9650 (4x3.0GHz, 1,333MHz FSB, DDR2)
  • Core 2 Quad Q9650 (4x3.0GHz, 1,333MHz FSB, DDR3)
  • AMD Phenom II X4 920 (4x2.8GHz, 1.8GHz HTT)
  • Core 2 Duo E8500 (2x3.16GHz, 1,333MHz FSB, DDR3)
  • Core 2 Duo E8500 (2x3.16GHz, 1,333MHz FSB, DDR2)
  • Core 2 Quad Q9550 (4x2.83GHz, 1,333MHz FSB, DDR3)
  • AMD Phenom II X4 (4x2.6GHz, 2.0GHz HTT)
  • Core 2 Quad Q9550 (4x2.83GHz, 1,333MHz FSB, DDR2)
  • Core 2 Quad Q9450 (4x2.66GHz, 1,333MHz FSB, DDR2)
  • Core 2 Quad Q9450 (4x2.66GHz, 1,333MHz FSB, DDR3)
  • Core 2 Quad Q6700 (4x2.66GHz, 1,066MHz FSB, DDR2)
  • Core 2 Quad Q6700 (4x2.66GHz, 1,066MHz FSB, DDR3)
  • AMD Phenom X4 9950 BE (4x2.6GHz, 2.0GHz HTT)
  • AMD Phenom X4 9850 BE (4x2.5GHz, 2.0GHz HTT)
  • AMD Athlon X2 7750 BE (2x2.7GHz, 1.8GHz HTT)
  • AMD Athlon X3 8750 BE (3x2.4GHz, 1.8GHz HTT)
    • 164.3
    • 162.9
    • 160.6
    • 156.7
    • 156.0
    • 155.5
    • 155.0
    • 152.0
    • 150.2
    • 149.5
    • 149.5
    • 149.4
    • 146.3
    • 145.6
    • 144.7
    • 144.5
    • 138.1
    • 125.4
    • 124.7
    • 122.5
    • 119.4
    • 115.8
50
75
100
125
150
175
Frames Per Second - higher is better
  • FPS
For Half-Life 2: Episode Two and the Source engine, the Phenom II again scores a win by largely exceeding the CPUs it's priced against - the 940 is faster than the Q9450, Q9550 and even Q9650, and is only half an fps away from the QX9770 with DDR3 too. It's still an fps or two away from the Core i7 920, but even the Phenom II X4 920 is not that far behind and still faster than the Intel E8500 and Q9550 CPUs. Generally, the going is very good for AMD and while not the absolute fastest CPUs, the table is nicely mixed up with green bars, rather than all sluggishly toiling at the bottom.
