SATA and M.2 Performance
Website: CrystalDiskMark
Gigabyte X99-Ultra Gaming Review Gigabyte X99-Ultra Gaming Review - SATA 6Gbps, M.2 and Audio
We test SATA performance with a Samsung SSD 850 Pro, as this is one of the fastest SSDs we've ever tested, and it can saturate the bandwidth of SATA 6Gbps ports.
For M.2 port testing, we use a Samsung SSD 950 Pro. This is rated at 2200MB/sec read and 900MB/sec write speeds - not quite saturating the M.2 PCI-E 3.0 x4 interface but enough to give it a good workout. We use CystalDiskMark's 32QD sequential test.
M.2
CrystalDiskMark
  • MSI X99A XPower Titanium
  • Gigabyte X99-Ultra Gaming
  • Asus X99-Deluxe II
  • Asus ROG Strix X99 Gaming
  • MSI X99A Gaming Pro Carbon
  • Gigabyte GA-X99-Designare EX
    • 2300
    • 960
    • 2299
    • 963
    • 2299
    • 959
    • 2299
    • 957
    • 2295
    • 962
    • 2294
    • 964
1000
1500
2000
2500
MB/sec
  • Read
  • Write
SATA 6Gbps
CrystalDiskMark
    • 562
    • 529
    • 560
    • 520
    • 559
    • 529
    • 559
    • 527
    • 559
    • 526
    • 558
    • 519
200
300
400
500
600
MB/sec
  • Read
  • Write
Rightmark Audio Analyzer
Publisher: Rightmark
We use the Playback/Recording test, first adjusting levels so they're within the benchmark parameters and then using 24-bit 192KHz tracks, we connect the line-in to the speaker/line-out jack using a standard 3.5mm audio cable. Following feedback we felt it important to include some results given that on-board audio is a hotly fought-over area with motherboards at the moment.
RightMark Audio Analyser
Dynamic Range
  • Gigabyte X99-Gaming 5P
  • Asus Sabertooth X99
  • Asus X99-A II
  • ASRock Fatal1ty X99M Killer
  • MSI X99A XPower AC
  • ASRock X99 Extreme 11
  • Asus X99 Deluxe
  • EVGA X99 Micro
  • Asus X99-Pro
  • Gigabyte X99M-Gaming 5
  • Gigabyte GA-X99-UD4P
  • Gigabyte GA-X99-Gaming 5
  • MSI X99S SLI Plus
  • MSI X99S MPower
    • 133
    • 105
    • 104
    • 104
    • 104
    • 104
    • 104
    • 104
    • 103
    • 102
    • 101
    • 101
    • 101
    • 99
    • 99
    • 97
    • 97
    • 94
    • 93
    • 91
50
75
100
125
150
dBA (Higher Is Better)
  • Dynamic Range (dBA)
Noise Level (dBA)
  • Asus X99-A II
  • Asus X99 Deluxe
  • Asus X99-Pro
  • EVGA X99 Micro
  • MSI X99S MPower
  • MSI X99S SLI Plus
    • -148
    • -105
    • -104
    • -104
    • -104
    • -104
    • -104
    • -104
    • -103
    • -102
    • -101
    • -101
    • -100
    • -100
    • -98
    • -97
    • -97
    • -93
    • -92
    • -92
50
75
100
125
150
dBA (Lower Is Better)
  • Noise Level (dBA)
Total Harmonic Distortion (THD) %
  • Asus X99-A II
  • Asus X99 Deluxe
  • MSI X99S SLI Plus
  • Asus X99-Pro
  • EVGA X99 Micro
  • MSI X99S MPower
    • 0.0000
    • 0.0027
    • 0.0028
    • 0.0031
    • 0.0033
    • 0.0039
    • 0.0039
    • 0.0041
    • 0.0058
    • 0.0071
    • 0.0079
    • 0.0079
    • 0.0080
    • 0.0085
    • 0.0088
    • 0.0091
    • 0.0095
    • 0.0110
    • 0.0120
    • 0.0120
0.005
0.0075
0.01
0.0125
THD Percentage (Lower Is Better)
  • THD %
