Intel NUC D33217CK Review
Written by Antony Leather
March 25, 2013 | 07:53
Tags: #core-i3 #embedded #intel-nuc #low-power #mini-itx #sff
Companies: #intel
Multi-tasking Performance
Website: MPC-HC
Website: 7-Zip
Multi-tasking is a phrase with which we're all familiar, because most of us are now used to running multiple applications at the same time. However, to run multiple applications well you need a powerful (ideally multi-core) CPU and plenty of RAM.
Our multi-tasking test performs a massive file backup (with encryption) using 7-Zip, while simultaneously playing back an HD movie file using mplayer, making it a demanding test for any PC.
Multi-tasking
Applications: mplayer and 7-Zip
  • Intel Core i7-3770K
  • Intel Core i7-2600K
  • Intel Core i5-3570K
  • Intel Core i5-2500K
  • Intel Core i5-2400
  • Intel Core i3-3220
  • AMD FX-8150
  • Intel Core i3-2100
  • AMD 5800K
  • AMD FX-8120
  • Intel NUC D33217CK (Core i3-3217U)
    • 1767
    • 1727
    • 1721
    • 1637
    • 1494
    • 1410
    • 1283
    • 1196
    • 1155
    • 1075
    • 782
1000
1500
2000
Score, higher is better
  • Stock Speed
Read our performance analysis.
Overall Score
The overall score is an unweighted mean average of the scores of the three individual tests.
Overall Score
Applications: Gimp, Handbrake, mplayer, 7-Zip
  • AMD FX-8350
  • AMD FX-8150
  • AMD 5800K
  • AMD FX-8120
    • 2403
    • 2248
    • 2217
    • 2116
    • 1850
    • 1694
    • 1660
    • 1563
    • 1465
    • 1372
    • 1328
    • 909
1000
1500
2000
2500
  • Stock Speed
