Intel NUC Kit NUC5i3RYK (Core i3-5010U) Review
Written by Antony Leather
February 11, 2015 | 13:48
Tags: #80211ac #broadwell #broadwell-nuc #htpc #intel-nuc #intel-nuc-review #m2
Companies: #intel
Left 4 Dead 2
Developer: Valve Software
From our Left 4 Dead 2 review:
'Not only does Left 4 Dead 2 provide a chance to test your skills against a whole host of new enemies and using a slew of new equipments, it also lets you play with the new modes and maps created by Valve – and the worst levels created by Valve are still twice as good as the best created by amateur map-makers.'
Left 4 Dead 2
1,280 x 720, 0x AA, 16x AF, high settings
  • AMD A10-5800K (4.4GHz)
  • AMD A10-5800K (3.8GHz)
  • Intel NUC5i3RYK (Core i3-5010U)
  • Intel NUC D54250WYK (Core i5-4250U)
  • Intel NUC DC53427RKE (Core i5-3427U)
  • Intel NUC D33217CK (Core i3-3217U)
    • 75
    • 105
    • 73
    • 102
    • 37
    • 53
    • 34
    • 53
    • 29
    • 51
    • 25
    • 47
50
75
100
Frames per second, higher is better
  • Minimum
  • Average
Left 4 Dead 2
1,680 x 1,050, 0x AA, 16x AF, high settings
    • 53
    • 68
    • 27
    • 37
    • 26
    • 38
    • 23
    • 36
    • 20
    • 34
20
30
40
50
60
70
  • Minimum
  • Average
Power Consumption
For the power consumption tests we aim to gauge real-world power draw. The power draw is measured via a power meter at the wall, so the numbers below represent the total system power draw from the mains, not the power consumption of a CPU itself. Measuring the power draw of any individual component in a PC is tricky to impossible to achieve. We used Prime95 to fully load the CPU.
Idle Power Consumption
For this test, we leave the PC doing nothing but displaying the Windows 7 desktop (with Aero enabled) for a few minutes and record the wattage drawn from the wall via a power meter.
Power Consumption (Idle)
Windows Aero enabled
  • Raspberry Pi (claimed power consumption)
  • Intel NUC Kit NUC5i3RYK (Core i3-5010U)
  • Intel Core i3-3220
    • 4
    • 9
    • 9
    • 11
    • 13
    • 46
20
30
40
50
Watts, lower is better
  • Stock Speed
Load Power Consumption
To generate a realistic load power consumption figure we load the CPU using Prime95's small FFT test, which mimics 100 percent load across all logical and physical cores.
Power Consumption (Load)
Unigene Heaven and Prime 95
    • 4
    • 15
    • 24
    • 27
    • 29
    • 78
20
30
40
50
60
70
80
  • Stock Speed
Corsair Sabre RGB Pro Wireless Mouse Review
September 17 2021 | 10:20
