Intel Haswell-E; Intel Core i7-5960X Review, X99 Chipset and DDR4
Written by Antony Leather
August 29, 2014 | 16:58
Tags: #haswell-e #haswell-e-review #intel-core-i7-5820k-review #intel-core-i7-5930k-review #intel-core-i7-5960x-review #lga2011-v3 #x99 #x99-review
Companies: #intel
Power consumption
For all of the performance tests, we disable all power-saving technology in order to give us a consistent set of results, and also best-case performance numbers - even though technologies such as Intel's SpeedStep might only take microseconds to kick in, that can make a difference in some tests.
However, for the power consumption tests we re-enable everything in order to get a real-world power draw. The power draw is measured via a power meter at the wall, so the numbers below are of total system power draw from the mains, not the power consumption of a CPU itself. Measuring the power draw of any individual component in a PC is tricky to impossible to acheive.
Idle Power Consumption
For this test, we leave the PC doing nothing but displaying the Windows 7 desktop (with Aero enabled) for a few minutes and record the wattage drawn from the wall via a power meter.
Power Consumption (Idle)
Windows Aero enabled
  • Intel Core i7-4770K (3.5GHz/4.7GHz)
  • Intel Core i7-4790K (4GHz/4.8GHz)
  • AMD FX-8350 (4GHz/4.8GHz)
  • Intel Core i7-4930K (3.4GHz/4.5GHz)
  • Intel Core i7-5960X (3GHz/4.45GHz)
  • Intel Core i7-3960X Extreme Edition (3.3GHz/4.7GHz)
    • 81
    • 100
    • 84
    • 109
    • 91
    • 157
    • 114
    • 126
    • 127
    • 139
    • 172
    • 205
100
150
200
Watts, lower is better
  • Stock Speed
  • Overclocked
Load Power Consumption
For this test, we want to only stress the CPU, so use the smallfft stress test of Prime95 to fully load all available processors (logical as well as physical). We leave Aero enabled, and wait a few minutes for any power saving technology to kick in and for the power consumption to level out before taking our reading.
Power Consumption (Load)
    • 137
    • 171
    • 154
    • 198
    • 212
    • 274
    • 220
    • 436
    • 274
    • 445
    • 283
    • 334
200
300
400
  • Stock Speed
  • Overclocked
Mod of the Month April 2019 in Association with Corsair
May 8 2019 | 13:30
