IPC Testing
Cinebench R15 (Single-Threaded) - IPC Comparison
64-bit, CPU test
  • Intel Core i7-7700K (4GHz)
  • Intel Core i7-6700K (4GHz)
  • Intel Core i5-7600K(4GHz)
  • Intel Core i3-7350K (4GHz)
    • 174
    • 173
    • 172
    • 170
100
150
200
Score (higher is better)
  • Score
Cinebench R15 (Multi-Threaded) - IPC Comparison
64-bit, CPU test
  • Core i5-7600K (4GHz)
    • 872
    • 872
    • 656
    • 433
200
300
400
500
600
700
800
900
  • Score
Ashes of the Singularity
DX12 GPU test, 'High' settings
  • Intel Core i5-7600K (5GHz)
  • Intel Core i3-7350K (5GHz)
    • 49
    • 70
    • 45
    • 66
20
30
40
50
60
70
Frames per Second
  • Minimum
  • Average
Power Consumption
For all of the overclocked performance tests, we disable all power-saving technology in order to give us a consistent set of results, and also best-case performance numbers - even though technologies such as Intel's SpeedStep might only take microseconds to kick in, that can make a difference in some tests.
However, for the stock speed results and power consumption tests, we re-enable everything in order to get a real-world power draw. The power draw is measured via a power meter at the wall, so the numbers below are of total system power draw from the mains, not the power consumption of a CPU itself. Measuring the power draw of any individual component in a PC is tricky to impossible to achieve.
We use Prime95's small FFTs test to put the CPU under 100 percent load, while idle power results are taken with the PC sitting at a Windows Aero-enabled desktop.
Intel Core i3-7350K Review Intel Core i3-7350K Review - IPC Testing and Power Consumption
Power Consumption (Idle)
Windows 10 desktop
  • Intel Core i5-6600K
  • Intel Core i7-7700K (5GHz)
  • Intel Core i7-6700K (4.8GHz)
  • Intel Core i5-6600K (4.8GHz)
  • Intel Core i5-7600K (5.1GHz)
    • 47
    • 47
    • 48
    • 50
    • 50
    • 64
    • 65
    • 70
    • 72
    • 73
20
30
40
50
60
70
80
Watts (lower is better)
  • Power Consumption
Power Consumption (Load)
Prime95 small FFTs test
    • 89
    • 107
    • 113
    • 125
    • 125
    • 129
    • 176
    • 186
    • 184
    • 188
100
150
200
  • Power Consumption
