Powercolor Radeon HD 4850 PCS+
Written by Harry Butler
September 23, 2008 | 12:52
Tags: #4850 #best #gpu #graphics-card #harry #hd-4850 #radeon #review
Companies: #amd #ati #powercolor
Crysis
Publisher: Electronic Arts
What can we say about this game that hasn’t been said already? Crysis was probably the most anticipated game on the PC last year and was released on November 16th 2007.
Crysis is seen by many as the poster boy for DirectX 10 and it will make your system cry, quite literally – it’s a monster! It doesn’t come as much of a surprise then, that the graphics are something special – they’re above and beyond anything we’ve ever seen in a PC game.
We tested the game using the 64-bit executable under both DirectX 9.0 and DirectX 10 with the 1.21 patch applied. We used a custom timedemo recorded from the Laws of Nature level which is more representative of gameplay than the built-in benchmark that renders things much faster than you're going to experience in game. We found that around 30-33 fps in our custom timedemo was sufficient enough to obtain a playable frame rate through the game. It's a little different to other games in that the low frame rates still appear to be quite smooth.
For our testing, we set all quality details to High and forced 8x Anisotropic Filtering in the driver menu as there is currently no support for it in game. We tested at 1280x1024, using 0x, 2x and 4x Anti Aliasing, 1680x1050 using 0x and 4x Anti Aliasing, 1920x1200 using 0x and 2xAA and 2560x1600 with 0xAA. By extensively testing using Anti Aliasing in very high resolutions, we'll be pushing even the bleeding edge hardware on test to the limit.
Powercolor Radeon HD 4850 PCS+ Crysis DX9 Powercolor Radeon HD 4850 PCS+ Crysis DX9
DirectX 9
Crysis
1280x1024, 0xAA, 8xAF, DX9, High Detail
  • ATI Radeon HD 4870 X2
  • Nvidia GeForce GTX 280
  • Nvidia GeForce GTX 260
  • ATI Radeon HD 3870 X2
  • Nvidia GeForce 9800 GTX+
  • Powercolor Radeon HD 4850 PCS+
  • ATI Radeon HD 4850
  • Nvidia GeForce 8800 GT
    • 78.6
    • 35.0
    • 56.0
    • 33.0
    • 50.9
    • 30.0
    • 45.9
    • 26.0
    • 44.2
    • 21.0
    • 39.0
    • 23.0
    • 37.9
    • 21.0
    • 36.3
    • 20.0
    • 30.5
    • 18.0
20
30
40
50
60
70
80
Frames Per Second
  • Average
  • Minimum
Crysis
1280x1024, 2xAA, 8xAF, DX9, High Detail
    • 66.3
    • 31.0
    • 51.1
    • 31.0
    • 46.1
    • 28.0
    • 38.1
    • 23.0
    • 33.3
    • 17.0
    • 33.2
    • 23.0
    • 30.9
    • 18.0
    • 29.3
    • 17.0
    • 26.5
    • 16.0
20
30
40
50
60
70
Frames Per Second
  • Average
  • Minimum
Crysis
1280x1024, 4xAA, 8xAF, DX9, High Detail
    • 63.4
    • 31.0
    • 48.3
    • 29.0
    • 43.6
    • 25.0
    • 36.7
    • 22.0
    • 32.7
    • 17.0
    • 30.2
    • 17.0
    • 28.9
    • 16.0
    • 28.0
    • 16.0
    • 24.2
    • 14.0
20
30
40
50
60
70
Frames Per Second
  • Average
  • Minimum
Crysis
1680x1050, 0xAA, 8xAF, DX9, High Detail
    • 58.5
    • 27.0
    • 40.5
    • 26.0
    • 36.6
    • 22.0
    • 31.9
    • 16.0
    • 31.9
    • 16.0
    • 31.3
    • 19.0
    • 30.2
    • 18.0
    • 29.0
    • 17.0
    • 24.6
    • 15.0
20
30
40
50
60
Frames Per Second
  • Average
  • Minimum
Crysis
1680x1050, 4xAA, 8xAF, DX9, High Detail
    • 46.8
    • 23.0
    • 38.4
    • 25.0
    • 34.6
    • 22.0
    • 28.9
    • 17.0
    • 23.5
    • 10.0
    • 22.7
    • 14.0
    • 21.9
    • 13.0
    • 19.9
    • 11.0
    • 16.6
    • 9.0
20
30
40
50
Frames Per Second
  • Average
  • Minimum
Crysis
1920x1200, 0xAA, 8xAF, DX9, High Detail
  • ATI Radeon 4870 X2
    • 46.8
    • 21.0
    • 35.9
    • 23.0
    • 32.4
    • 20.0
    • 29.3
    • 17.0
    • 25.6
    • 13.0
    • 25.1
    • 15.0
    • 23.9
    • 15.0
    • 22.7
    • 13.0
    • 19.9
    • 11.0
20
30
40
50
Frames Per Second
  • Average
  • Minimum
Crysis
1920x1200, 2xAA, 8xAF, DX9, High Detail
    • 38.9
    • 18.0
    • 32.6
    • 20.0
    • 29.2
    • 19.0
    • 23.7
    • 15.0
    • 18.9
    • 10.0
    • 18.8
    • 11.0
    • 18.1
    • 11.0
    • 17.5
    • 6.0
    • 15.5
    • 9.0
20
30
40
Frames Per Second
  • Average
  • Minimum
Crysis
2560 x 1600, 0xAA, 8xAF, DX9, High Detail
    • 27.1
    • 9.0
    • 22.5
    • 12.0
    • 20.1
    • 10.0
    • 17.2
    • 8.0
    • 14.6
    • 5.0
    • 14.4
    • 8.0
    • 14.2
    • 7.0
    • 13.5
    • 6.0
    • 11.0
    • 4.0
10
15
20
25
30
Frames Per Second
  • Average
  • Minimum
The big surprise here is the 3870 X2, which, with the new Catalyst 8.8 drivers, has obviously received some significantly optimised driver profiles, allowing it to deliver better performance. As before, the Powercolor Radeon HD 4850 PCS+ fall just where we'd expect it to, with the higher core clock allowing to better the stock 4850 by a couple of frames per second.
