Overclocking AMD's Phenom II X3 720 BE
May 11, 2009 | 11:03
Tags: #720 #be #bios #black #budget #core #edition #enthusiast #guide #ii #motherboard #overclocking #performance #phenom #triple #x3
Companies: #amd #asus #msi
Lavalys Everest 4.60.1540 Beta Memory Performance
Website: Lavalys
Everest Memory Performance Test
  • AMD Phenom II X3 720 Black Edition (3x3.7GHz)
  • Intel Core 2 Quad Q6600 (4x3.5GHz)
  • Intel Core 2 Duo E7500 (2x4.2GHz)
  • AMD Phenom II X3 720 Black Edition (3x2.8GHz)
    • 10084
    • 8690
    • 12205
    • 8177
    • 7098
    • 7655
    • 8417
    • 8465
    • 8405
    • 8185
    • 6663
    • 9910
5000
7500
10000
12500
MB/s (higher is better)
  • Read MB/s
  • Write MB/s
  • Copy MB/s
Everest Memory Latency Test
  • Intel Core 2 Duo E7500 (2x4.xxGHz)
  • 44.7
  • 55.6
  • 61.7
  • 63.0
20
30
40
50
60
70
Nanoseconds (lower is better)
Raw memory performance for the AMD CPU is suitably massive, since it not only compares DDR3 to the DDR2 used by the Intel Core 2 CPUs, but also it shows up the massive bandwidth difference between the direct connect AMD CPUs and Intel's old front side bus model. Not only is the latency 38 percent lower, it also has large read and memory copy performance advantages, but little in the way of write speed when the Intel CPUs have their front side bus cranked way up.
SiSoftware Sandra Lite 2009.SP1 Beta (15.42)
Website: Sisoftware
Sisoft Sandra Unbuffered Memory Test
  • 16179
  • 12694
  • 7674
  • 7100
5000
7500
10000
12500
15000
17500
Sisoft Sandra Random Memory Latency Test
  • 66
  • 75
  • 76
  • 85
20
30
40
50
60
70
80
90
Sisoft Sandra is a multi-threaded memory test, so here the AMD also yields a fantastic raw bandwidth performance that it claims is over twice as much as the E7500 at 4.2GHz. The latency difference is lower though, at just 13.6 percent.
