Cinebench R11.5 64-bit
Download from: www.maxon.net
Cinebench R11.5 uses Maxon's Cinema 4D engine to render a photo-realistic scene of some shiny balls and weird things (we miss the motorbike). The scene is highly complex, with reflections, ambient occlusion and procedural shaders so it gives a CPU a tough workout.
As Cinema 4D is a real-world application - used on films such as Spider-Man and Star Wars - Cinebench R11.5 can be viewed as a real-world benchmark.
Cinebench R11.5
64-bit, CPU test
  • Intel Core i7-980X Extreme Edition (4.4GHz)
  • Intel Core i7-2600K (4.85GHz)
  • Intel Core i7-980X Extreme Edition (3.33GHz)
  • Intel Core i5-2500K (4.9GHz)
  • AMD Phenom II X6 1100T Black Edition (4.2GHz)
  • Intel Core i7-950 (4.3GHz)
  • Intel Core i7-2600K (3.4GHz)
  • Intel Core i5-2400 (up to 3.99GHz)
  • AMD Phenom II X6 1100T Black Edition (3.3GHz)
  • Intel Core i7-950 (3.06GHz)
  • Intel Core i5-2500K (3.3GHz)
  • Intel Core i5-2400 (3.1GHz)
  • Intel Core i5-760 (4.1GHz)
  • Intel Core i5-760 (2.8GHz)
  • 11.22
  • 9.42
  • 8.95
  • 7.71
  • 7.40
  • 7.31
  • 6.88
  • 6.05
  • 5.90
  • 5.57
  • 5.47
  • 5.15
  • 4.89
  • 3.94
8
10.5
13
Points, higher is better
WPrime
Download from: www.wprime.net
WPrime is a multi-threaded maths calculation benchmark that counter-intuitively uses square roots rather than prime numbers. The standard benchmark uses 32 million numbers, calculating the square root via 'a recursive call of Newton's method for estimating functions'. We're not sure what that means either, but you can read the full blurb on WPrime's About page. What we do know is that WPrime scales well across multiple CPU cores, and can push a CPU to 100 per cent load on all its cores.
To run the benchmark, first visit the core count to check that WPrime will load all physical and logical cores, and then run the 32M test. The results are expressed as a time taken to calculate the square root of the set of numbers (32 million in the standard test). A lower score is better.
WPrime
32M test, all available process threads
  • 4.135
  • 5.273
  • 5.287
  • 6.522
  • 6.894
  • 7.222
  • 7.270
  • 8.312
  • 8.721
  • 8.931
  • 9.705
  • 10.700
  • 11.625
  • 12.230
8
10.5
13
Seconds, lower is better
Read our performance analysis of the Core i5-2400, Core i5-2500K and Core i7-2600K separately.
3D Printing GPU Support Brackets
February 17 2020 | 09:00
