AMD Phenom II X4 965 BE C3 Review
November 4, 2009 | 09:13
Tags: #2 #benchmarks #c3 #core #cpu #ddr3 #deneb #die #ii #oc #overclock #overclocking #performance #phenom #processor #quad #realworld #review #sleep #x4
Companies: #amd #test
Cinebench R10 64-bit
Download from: www.maxon.net
Cinebench R10 uses Maxon's Cinema 4D engine to render a photo-realistic scene of a shiny motorbike. The scene is highly complex, with reflections, ambient occlusion and procedural shaders so it gives a CPU a tough workout.
The test can be in run in single-threaded 1CPU mode or multi-threaded xCPU mode - just click the respective button. In this way, Cinebench R10 is useful for gauging the performance of each execution core of a CPU, as well as its overall performance.
As Cinema 4D is a real-world application - used on films such as Spider-Man, Star Wars among others - Cinebench R10 can be viewed as either a real-world benchmark or a theoretical one.
AMD Phenom II X4 965 BE C3 Review Cinebench and wPrime AMD Phenom II X4 965 BE C3 Review Cinebench and wPrime
Cinebench R10 (64-bit)
x64 Version - xCPU, 800x600 Image
  • Intel Core i7-920
  • Intel Core i5-750
  • AMD Phenom II X4 965 C3 Black Edition
  • AMD Phenom II X4 965 Black Edition
  • AMD Phenom II X4 955 Black Edition
    • 14973
    • 23052
    • 14184
    • 20126
    • 14101
    • 16571
    • 13960
    • 16116
    • 13504
    • 16172
10000
15000
20000
25000
points (higher is better)
  • Stock Speed
  • Overclocked
The extra MHz on the 4GHz C3 965 Black Edition yield a slightly better score, but there isn't an epic change. Interestingly the stock performance also went up slightly too. Comparatively, at just 2.66GHz the Core i5 and i7 still exceed the 3.2 to 3.4GHz Phenom IIs, and overclocked, they annihilate them.
WPrime
Download from: www.wprime.net
WPrime is a multi-threaded maths calculation benchmark that counter-intuitively uses square roots rather than prime numbers. The standard benchmark uses 32 million numbers, calculating the square root via 'a recursive call of Newton's method for estimating functions'. We're not sure what that means either, but you can read the full blurb on WPrime's About page. What we do know is that WPrime scales well across multiple CPU cores, and can push a CPU to 100 per cent load on all its cores.
To run the benchmark, first visit the core count to check that WPrime will load all physical and logical cores, and then run the 32M test. The results are expressed as a time taken to calculate the square root of the set of numbers (32 million in the standard test). A lower score is better.
WPrime v2.00
32M test, all process threads
  • Intel Core i7-920
  • Intel Core i5-750
    • 9.425
    • 6.305
    • 10.764
    • 9.126
    • 10.767
    • 9.594
    • 11.524
    • 9.459
    • 12.306
    • 8.719
8
10.5
13
seconds (lower is better)
  • Stock Speed
  • Overclocked
Stock performance in multi-threaded prime calculation is very good for AMD, and overclocked the new C3 965 Black Edition takes about half a second off the old model. At stock speeds they all out perform the similarly priced i5-750, although overclocked to the same 4GHz sends the i5 back into the lead.
Mod of the Month February 2021 in Association with Corsair
March 26 2021 | 18:30
