AMD Phenom II X4 965 BE C3 Review
November 4, 2009 | 09:13
Tags: #2 #benchmarks #c3 #core #cpu #ddr3 #deneb #die #ii #oc #overclock #overclocking #performance #phenom #processor #quad #realworld #review #sleep #x4
Companies: #amd #test
Lavalys Everest
Download from: www.lavalys.com
Everest is a comprehensive suite of benchmarking tools that can gauge the theoretical performance of every sub-system and component of your PC. We use the Memory and Cache benchmark to see how data flows into and out of the CPU.
Open the application and go to the Tools menu. Then click Cache and Memory Benchmark and click the Start Benchmark button. Everest will test the speed of all levels of CPU cache as well as memory throughput.
Everest Memory Performance Test
  • Intel Core i5-750
  • Intel Core i7-920
  • AMD Phenom II X4 955 Black Edition
  • AMD Phenom II X4 965 Black Edition
  • AMD Phenom II X4 965 C3 Black Edition
    • 12173
    • 9666
    • 13317
    • 11993
    • 9657
    • 14117
    • 8082
    • 6730
    • 10104
    • 8045
    • 6765
    • 10159
    • 8033
    • 6789
    • 10123
5000
7500
10000
12500
15000
MB/s (higher is better)
  • Read MB/s
  • Write MB/s
  • Copy MB/s
Everest Memory Performance Test (OC)
  • Intel Core i7-920
  • Intel Core i5-750
    • 17595
    • 14441
    • 20510
    • 16841
    • 14249
    • 18059
    • 10211
    • 8138
    • 12368
    • 10313
    • 8620
    • 12555
    • 10040
    • 9772
    • 12465
10000
15000
20000
  • Read MB/s
  • Write MB/s
  • Copy MB/s
Everest Memory Latency Test
  • Intel Core i5-750
  • Intel Core i7-920
  • 54.8
  • 54.9
  • 55.3
  • 56.1
  • 69.0
20
30
40
50
60
70
Nanoseconds (lower is better)
Everest Memory Latency Test (OC)
  • Intel Core i5-750
  • Intel Core i7-920
  • 42.9
  • 44.4
  • 45.1
  • 45.5
  • 47.6
20
30
40
50
While at stock speeds (1,333MHz CL9), the new 965 Black Edition matches its older brothers, although overclocked the read performance and latency seems to suffer a little, despite us optimising the timings at 1,600MHz. The much greater 2.8GHz memory controller clock naturally yields a much higher write performance though.
