Corsair Carbide Series Air 240 Review
Written by Antony Leather
August 15, 2014 | 14:01
Tags: #cube-case #micro-atx-case #mini-itx-case #water-cooling
Companies: #corsair
Cooling Performance
As the Carbide Series Air 240 was too small for our usual micro-ATX test cooler, we've used out mini-ITX case test kit to obtain cooling performance numbers to compare the case against others we've tested. We've also highlighted similar micro-ATX cases that couldn't fit our usual test gear.
Our mini-ITX test kit includes:
  • CPU: Intel Core i5-2500K overclocked to 4.3GHz using a vcore of 1.3V.
  • Graphics card: GeForce GTX 570 1.3GB
  • Motherboard: Asus P8Z77-I Deluxe
  • RAM: 4GB Kingston DDR3 1600MHz memory
  • PSU: Enermax Eco 82+ 620W PSU
  • CPU cooler: Zalman CNPS 8900 low-profile cooler
While some cases can house larger coolers, for the results to be comparable, we needed to pick a cooler that was going to fit in as many cases as possible. We therefore opted for a low-profile cooler. This will give a good idea of how well the case is able to remove heat from the system - our primary concern in case testing - although you can probably expect to achieve better results by using a larger cooler if the case in question supports it.
The graphics card fan was locked at 70 per cent speed and the system was loaded using Prime95 and Unigine's Heaven benchmark. We used Realtemp and GPU-Z to monitor the temperatures, taking the maximum values when the readings had plateaued.
Case performance - CPU Delta T
Arranged by CPU Delta T
  • SilverStone Raven RVZ01
  • Silverstone Sugo SG08 (max speed)
  • BitFenix Prodigy
  • Silverstone Sugo SG08 (min speed)
  • Silverstone FT03-Mini
  • Fractal Design Node 304 (max speed)
  • Cooler Master Elite 130 Advanced
  • Lian Li PC-TU200
  • Corsair Obsidian 250D
  • Lian Li PC-V360 (micro-ATX)
  • Lian Li Lian Li PC-Q28
  • In-Win 901 (Zalman ZM-F2 92mm + Noctua NF-F12 120mm) (micro-ATX)
  • Lian Li PC-V358 (micro-ATX)
  • EVGA Hadron Air
  • BitFenix Phenom
  • Corsair Carbide Series Air 240
  • Cooler Master Elite 120 Advanced
  • Antec ISK600
  • Fractal Design Node 304 (min speed)
  • SilverStone Precision PS09 (micro-ATX)
  • In-Win 901 (no fans) (micro-ATX)
    • 41
    • 46
    • 41
    • 53
    • 43
    • 48
    • 44
    • 56
    • 48
    • 58
    • 49
    • 47
    • 49
    • 55
    • 49
    • 63
    • 52
    • 46
    • 53
    • 53
    • 53
    • 59
    • 54
    • 44
    • 54
    • 53
    • 54
    • 54
    • 54
    • 57
    • 55
    • 50
    • 55
    • 56
    • 56
    • 51
    • 59
    • 49
    • 69
    • 77
    • 77
    • 65
20
30
40
50
60
70
80
°C, lower is better
  • CPU delta T
  • GPU delta T
Case performance - GPU Delta T
Arranged by GPU Delta T
  • BitFenix Prodigy
  • Corsair Carbide Series Air 240 (micro-ATX)
  • Antec ISK600
  • EVGA Hadron Air
  • BitFenix Phenom
  • Lian Li PC-Q28
  • Lian Li PC-TU200
    • 54
    • 44
    • 41
    • 46
    • 49
    • 47
    • 52
    • 47
    • 43
    • 48
    • 59
    • 49
    • 55
    • 50
    • 56
    • 51
    • 41
    • 53
    • 53
    • 53
    • 54
    • 53
    • 54
    • 54
    • 49
    • 55
    • 44
    • 56
    • 55
    • 56
    • 54
    • 57
    • 48
    • 58
    • 53
    • 59
    • 49
    • 63
    • 77
    • 65
    • 69
    • 77
20
30
40
50
60
70
80
°C, lower is better
  • CPU delta T
  • GPU delta T
