Antec Dark Fleet DF-85 Case Review
Written by Antony Leather
July 22, 2010 | 08:27
Tags: #aluminium-case #dark-fleet #full-tower #haf #high-airflow #steel-case #tower-case
Companies: #antec
Performance Analysis
While we only have a small selection of cases to compare against which we've had time to re-test with our new test kit, the Dark Fleet DF-85 is clearly a monster when it comes to cooling. It wiped the floor with the competition with its fans at full speed and even managed to better the Twelve Hundred by a few degrees recording slightly lower CPU and GPU delta T's.
Unfortunately it's a noisy beast at these speed settings - but thankfully, the Dark Fleet performed only slightly worse at its slowest fan speed setting. The CPU only became 2°C hotter while the GPU actually remained the same so in most situations, using the fans at their lowest speed setting will mean a small difference in temperatures while the difference to your ears will be huge.
Antec Dark Fleet Case Review Antec Dark Fleet DF-85 Conclusion
Conclusion
As we had an Antec Twelve Hundred to hand, we couldn't help but instigate a mini clash of the titans with the Dark Fleet DF-85 going head to head with our trusty old favourite. The two roof-mounted 140mm fans are clearly doing just as good a job as the 200mm Big Boy fan in the Twelve Hundred and the absence of drive modules may also improve airflow. However, it's a little louder, more expensive and far uglier. The Dark Fleet DF-85 does have an abundance of features, including comprehensive fan-speed control, 2.5in and USB 3 support though.
Compared with the other cases we've tested recently, the issue of its unappealing looks becomes even more obvious, as the Dark Fleet DF-85 is only slightly better at cooling. As such, we'd recommend holding off from buying the Dark Fleet DF-85 at the moment.
  • Cooling
  • x
  • x
  • x
  • x
  • x
  • x
  • x
  • x
  • x
  • 9/10
  • Features
  • x
  • x
  • x
  • x
  • x
  • x
  • x
  • x
  • x
  • 9/10
  • Design
  • x
  • x
  • x
  • x
  • x
  • x
  • x
  • 7/10
  • Value
  • x
  • x
  • x
  • x
  • x
  • x
  • x
  • x
  • 8/10
  • Overall
  • x
  • x
  • x
  • x
  • x
  • x
  • x
  • x
  • 8/10
Score Guide
