Asus Maximus VIII Gene Review
Written by Antony Leather
August 19, 2015 | 09:06
Tags: #best-z170-board #gene #lga1151-board #micro-atx-board #rog #z170
Companies: #asus
PCMark 8 Video Editing
Video Editing v2 Part 2 (Creative 3.0 test suite)
This workload uses FFmpeg to apply video enhancement filters to a high bitrate H.264 video and then encode it to a format suitable for distribution. The FFmpeg binary used is custom built by Futuremark using a development version of the source available from the project's code repository. The test applies a deshaking filter to a source video at 3,840 x 2160 (4K UHD) before scaling down and outputting at 1,920 x 1,080 (1080p).
PCMark 8 4K Video Editing
Part 2 test
  • Asus Maximus VIII Gene (4GHz/4.8GHz)
  • Asus Z170-Deluxe (4GHz/4.8GHz)
    • 111
    • 98
    • 112
    • 98
50
75
100
125
Seconds, lower is better
  • Stock
  • Overclocked
PCMark 8 Photo Editing V2
This workload involves making a series of adjustments to a set of photographs using ImageMagik - an open-source image processing library to adjust brightness, contrast, saturation and gamma. When a favourable balance is found, the changes are then applied to the rest of the images in the set. TIFF files up to 67MB in size are used.
Load image matrix + adjusting times
    • 31
    • 29
    • 31
    • 30
10
15
20
25
30
35
  • Stock
  • Overclocked
SATA and M.2 Performance
Website: CrystalDiskMark
We tested the SATA and performance with a Samsung 850 Pro, as this is one of the fastest SSDs we've ever tested, and it can saturate the bandwidth of SATA 6Gbps ports.
For the M.2 port, we used a Kingston KyperX Predator SSD. This is rated at 1,400MB/sec read - not quite saturating the M.2 interface but we've been unable to get our mitts on anything faster for long term testing as the interface is still in its infancy.
SATA 6Gbps and M.2 Performance
CrystalDiskMark
  • Asus Z170-Deluxe (Intel M.2)
  • Asus Maximus VIII Gene (Intel M.2)
  • Asus Maximus VIII Gene (Intel SATA 6Gbps)
  • Asus Z170-Deluxe (Intel SATA 6Gbps)
  • Asus Z170-Deluxe (ASMedia 6Gbps)
    • 1370
    • 664
    • 1277
    • 662
    • 522
    • 495
    • 521
    • 493
    • 384
    • 397
500
750
1000
1250
1500
MB/sec, higher is better
  • Read
  • Write
