Intel Core i9-10900K Review
Written by bit-tech Staff
May 20, 2020 | 14:00
Tags: #14nm #coffee-lake #coffee-lake-refresh #x299 #z390
Companies: #intel
Manufacturer: Intel
UK price (as reviewed): £499 (inc. VAT)
US price (as reviewed): $488 (exc. tax)
Intel is today launching a wide range of 10th Gen Core processors that have previously been known by the Comet Lake S codename. Headline features over 9th Gen Core include more cores, higher frequencies, more cache, faster memory speeds, and hyperthreading across the entire portfolio.
The underlying architecture is ostensibly the same as 9th, which in turn can trace direct origins all the way back to the Skylake generation of 2015. Intel's well-documented problems in shifting on over to a space- and energy-saving 10nm process for the bulk of its chips forces 10th Gen desktop to persevere with a refined 14nm node.
Nevertheless, the new Core family makes a lot more sense from a core-and-thread count point of view, and compares well against current AMD competition.
Model Cores/Threads Base Freq Boost Freq Smart Cache TDP  Included cooler SEP (USD) Availability
Core i9-10900K 10/20 3.7GHz 5.2GHz 20MB 125W No $488 May 20, 2020
Core i7-10700K 8/16 3.8GHz 5.1GHz 16MB 125W No $374 May 20, 2020
Core i5-10600K 6/12 4.1GHz 4.8GHz 12MB 125W No $262 May 20, 2020
Core i5-10500 6/12 3.1GHz 4.5GHz 12MB 65W Yes $192 May 20, 2020
Core i5-10400 6/12 2.9GHz 4.3GHz 12MB 95W Yes $182 May 20, 2020
Core i3-10320 4/8 3.8GHz 4.6GHz 8MB 65W Yes $154 May 20, 2020
Core i3-10300 4/8 3.7GHz 4.4GHz 8MB 65W Yes $143 May 20, 2020
Core i3-10100 4/8 3.6GHz 4.3GHz 6MB 65W Yes $122 May 20, 2020
The above table defines the key characteristics of various models from each family. There's a specific core-and-thread count for each range, making understanding the various models simpler than 9th Gen. Comet Lake S represents the first time Intel has provided 10 cores and 20 threads on a mainstream platform. Augmenting the extra parallelism, which is great for multithreaded applications, is higher speeds. Intel says reducing the thickness of the processor silicon, which is a poor conductor of heat, whilst simultaneously increasing the thickness of the integrated heatspreader, which is a good conductor, enables 10th Gen chips to push away heat more quickly, helping raise frequency.
Core i9-10900K runs at 5.2GHz on up to two cores under Turbo Boost 3.0. All-core speed is also decent, at 4.8GHz. It can actually run at 5.3GHz/4.9GHz for those two parameters if temperature is kept below 70°C under a technology known as Thermal Velocity Boost. It's this heightened frequency that allows Intel to proclaim 10th Gen Core as the world's fastest gaming chips.
Pricing is roughly in-line with the same model numbers from the previous generation. This ought to mean a nice uptick in performance without having to shell out more cash. That would be the case if these processors ran on the LGA1151v2 form factor and Z390 chipset that most enthusiasts are familiar with. Intel, however, chooses this juncture to move 10th Gen Core to 400-series chipsets harnessing an LGA1200 socket. If it's not clear, these processors need a brand-new motherboard, too, and they are not backwards-compatible with 9th Gen, or earlier, models. That is the price for adopting new technology this time around.
A couple more points to mention. Intel also increases the TDP, or power, of the premier processors, with the unlocked K-series from the Core i9, i7, and i5 families now consuming up to 125W, up from 95W. There are other models in the various ranges, suffixed with either F (no graphics) or T (35W, low-power), but it seems strange that the bulk are offered in only 65W or 125W parts - one ought to expect 95W chips somewhere. Intel carries over Turbo Boost 3.0 to Core i7 but removes Thermal Velocity Boost. Both Core i7 and i9 receive memory-frequency upgrades, to 2,933MHz, though the remainder of 10th Gen is stuck on DDR4-2,666MHz.
Core i9-10900K is definitely going to be faster than Core i9-9900K in every meaningful scenario thanks to its extra number of cores and higher peak frequencies. The question for those looking at a premier CPU for that next build is whether Intel, already top dog in gaming, has done enough to go toe-to-toe against the AMD Ryzen 9 processors that, on paper, still have even more muscle, particularly for rendering applications.
