Gigabyte GA-E350N-USB3 Review
February 23, 2011 | 08:31
Tags: #apu #brazos #htpc #mini-itx #motherboard #performance #result #review
Companies: #amd #gigabyte #test
Starcraft II
Developer: Blizzard Entertainment
From our StarCraft 2 review:
The game play may be a decade old but it’s been balanced and tuned to a razor sharp point before being wrapped in an engrossing storyline and excellent campaign mode. The game is chock full of quality missions and set pieces and while there are some ideas that fall a bit flat, the highlights shine through like a high power laser through wet toilet paper.
Gigabyte GA-E350N-USB3 Review GA-E350N-USB3 - Starcraft II, Team Fortress 2 and CoD: Modern Warfare 2
StarCraft II
1,280 x 720, 'Medium' Graphics Preset, 4x4 with 7 AI
  • Core i5-2500k [1,700MHz GPU]
  • Core i5-2500k [1,100MHz GPU]
  • AMD Radeon HD 4250 [560MHz]
  • Core i5-661 [900MHz GPU]
  • Core i5-661 [733MHz GPU]
  • AMD Radeon HD 6310 [500MHz]
    • 34
    • 27
    • 33
    • 26
    • 24
    • 17
    • 17
    • 14
    • 14
    • 12
    • 11
    • 8
10
15
20
25
30
35
FPS, Higher Is Better. Sorted by min FPS.
  • Average (FPS)
  • Minimum (FPS)
StarCraft II [Cost of Performance]
  • AMD Radeon HD 4250 [560MHz GPU]
  • AMD Radeon HD 6310 [500MHz GPU]
  • 10.3
  • 10.7
  • 11.8
  • 15.6
  • 17.4
  • 20.2
10
15
20
£ per (min) FPS generated (less is better value)
Gigabyte GA-E350N-USB3 Review GA-E350N-USB3 - Starcraft II, Team Fortress 2 and CoD: Modern Warfare 2For a full performance analysis of the above graphs, see page 8. We tested Starcraft II to find out what was actually playable and found that we had to turn down everything to the absolute lowest settings to achieve anything near this, and even then the average frame rate was 20fps with notable dips and stutters. At the lowest settings, the game frankly doesn't look great either, as you can see.
Best Playable Settings
Following on from our previous look at the VIA Nano Dual-Core, where we covered the best playable settings for Call of Duty: Modern Warfare 2 and Team Fortress 2, we decided to put the AMD E-350 through the same process.
Best Playable Settings:
  • Resolution: 1,280 x 720
  • Graphics Detail: High
  • Detail Level: All enabled apart from soften smoke edges
  • Anti-aliasing: None
At the settings above, the frame rate counter would consistently average high 20s to low 30s during game play. However, enabling the Extra detail level caused this to drop to a pretty consistent 20fps. Turning on the soften smoke edges feature at any time would cause a drop to 10-15fps whenever there was an explosion, so this needed to be disabled. Higher resolutions were also too much for the Radeon HD 6310 GPU too.
Gigabyte GA-E350N-USB3 Review GA-E350N-USB3 - Starcraft II, Team Fortress 2 and CoD: Modern Warfare 2 Gigabyte GA-E350N-USB3 Review GA-E350N-USB3 - Starcraft II, Team Fortress 2 and CoD: Modern Warfare 2
Team Fortress 2
  • Resolution: 1,280 x 720 (1,680 x 1,050)
  • Anisotropic Filtering: 8x
  • Reflections: World
  • Multicore Rendering: Enabled
We found that we could bump up Team Fortress 2's detail settings above that of the VIA Nano-Dual core (with Chrome 520 graphics IGP) to include 8x anisotropic filtering and world reflections, and it still remained fast and playable in multiplayer mode. Increasing the resolution to 1,680 x 1,050 at the same settings also resulted in a generally playable frame rate, with the occasional stutter to 10-15fps. You could get away with this, depending on the map.
