SilverStone SX600-G 600W PSU Review
Written by bit-tech Staff
January 16, 2015 | 12:34
Tags: #sfx-psu
Companies: #silverstone
+12V Rail Tests
For these tests, we take a reading of the voltage output of each PSU's 12V rail (or rails, if it uses a multi-rail design). This is done at three load levels: low, medium and high, which vary based on the wattage of PSU being tested. We are looking for results as close to 12V as possible. Higher loads are more likely to highlight any instabilities. Any output that falls outside of Intel's specifications is considered a fail and highlighted in red.
+12V Rail Output - Low Load (200W)
ATX spec limit: 11.4V - 12.6V
  • SilverStone SX600-G 600W
  • Antec EDGE 650W
    • 12.12
    • 12.16
8
10.5
13
Volts (blue = pass; red = fail)
  • 200W load test
+12V Rail Output - Medium Load (400W)
  • Antec EDGE 650W
    • 11.99
    • 12.02
8
10.5
13
  • 400W load test
+12V Rail Output - High Load (600W)
  • Antec EDGE 650W
    • 11.88
    • 11.82
8
10.5
13
  • 600W load test
