Intel Haswell vs AMD Richland - the GPU test
Written by Antony Leather
July 2, 2013 | 10:01
Tags: #a10-6800k #core-i7-4770k #crossfire #dual-graphics
Companies: #haswell #intel-and-amd
Unigene Heaven 4.0
Website: http://unigine.com
From Unigene's website: Heaven Benchmark with its current version 4.0 is a GPU-intensive benchmark that hammers graphics cards to the limits. This powerful tool can be effectively used to determine the stability of a GPU under extremely stressful conditions, as well as check the cooling system's potential under maximum heat output. It provides completely unbiased results and generates true in-game rendering workloads, supporting DirectX 11 and OpenGL 4.0.
Unigene Heaven
1,920 x 1,080, default settings
  • AMD A10-6800K
  • Intel Core i7-4770K
  • Intel Core i3-3220
    • 7
    • 17
    • 5
    • 14
    • 3
    • 13
8
10.5
13
15.5
18
Frames per second (higher is better)
  • Minimum
  • Maximum
Video encoding with Handbrake
Website: http://handbrake.fr
HandBrake is a free tool for converting video from nearly any format to a selection of modern, widely supported codecs. We used the standard 0.9.9 version an also the OpenCL and Quick Sync Beta versions.
Handbrake Video encoding
High Profile, Ultrafast x264 encoding, 15,000kbps avg bitrate
  • Intel Core i7-4770K (Quick Sync Beta, QSV Preset)
  • Intel Core i7-4770K (Quick Sync Beta)
  • AMD A10-6800K (OpenCL Beta)
  • AMD A10-6800K
    • 238
    • 113
    • 76
    • 42
    • 36
100
150
200
250
  • FPS
Video encoding with Cyberlink MediaEspresso
MediaEspresso supports various guises of hardware acceleration including AMD's Accelerated Parallel Processing, Nvidia's Cuda and Intel's Quick Sync. We used version 6.7 and ran tests with hardware acceleration enabled and disabled while converting a 1080p 1GB .mov video file to 720p H.264.
Cyberlink MediaEspresso Video encoding
1,080p .mov to 720p .m2ts H.264 conversion
  • Intel Core i7-4770K (gpu acceleration)
  • Intel Core i7-4770K (w/o gpu acceleration)
  • AMD A10-6800K (gpu acceleration)
  • AMD A10-5800K (gpu acceleration)
  • AMD A10-6800K (w/o gpu acceleration)
  • AMD A10-5800K (w/o gpu acceleration)
    • 14
    • 82
    • 105
    • 112
    • 205
    • 219
100
150
200
250
Seconds second (lower is better)
  • Seconds
