Testing and Results
We've included results from several CPU coolers in each test. Not all are present in all socket tests because some aren't compatible. In this case we've tried to include a similar cooler from that particular company, such as the Noctua NH-C12P which is compatible with LGA 775 and Socket AM2+, but not with LGA1366. In this case we've used Noctua's NH-U12P SE 1366.
Where CPU coolers had alternative fan speeds, we've tested at both the lowest and highest fan speed settings and recorded idle and load delta T results for each setting to give you some idea as to how much performance is affected.
We've also included the reference cooler for each socket which is a good indicator of what kind of improvement you'd see when upgrading. For instance, you certainly wouldn't want to buy a third-party cooler that performs worse than the reference cooler.
Delta T is the difference in °C between the ambient temperature and the recorded temperature of the hardware, in this case the CPU. We used Core Temp 0.99.4 to take temperature readings of the CPU from the Digital Thermal Sensor (DTS) embedded in the core of every modern CPU, at idle and under load while using the smallfft test in Prime95.
A multimeter thermal attachment probe was used to take the ambient air temperature three inches away from the case's primary intake location. The delta T is a more accurate and comparable method of recording temperature because the ambient room temperature of our test lab fluctuates from day to day.
For Socket AM2+ we used a 3GHz AMD Phenom II X4 940 Black Edition overclocked to 3.6GHz with the vcore boosted to 1.6V. The LGA1366 test rig used a 3.2GHz Core i7-965 Extreme Edition overclocked to 3.6GHz with a vcore of 1.3V.
LGA1366 Results
Arranged by 100% CPU Load Delta T value
  • Titan Fenrir Xmas Edition (high speed)
  • Titan Fenrir TTC-NK85TZ (high speed)
  • Thermalright Ultra eXtreme 120
  • Titan Fenrir Xmas Edition (low speed)
  • Titan Fenrir TTC-NK85TZ (low speed)
  • Akasa Freedom Tower
  • Cooler Master V8 (high speed)
  • Akasa Nero
  • Noctua NH-U12P SE1366 (low speed)
  • Noctua NH-U12P SE1366 (high speed)
  • Tuniq Tower 120 Extreme (high speed)
  • Nesteq Silent Freezer 1200
  • Intel reference cooler
    • 15
    • 44
    • 15
    • 44
    • 16
    • 45
    • 17
    • 48
    • 17
    • 48
    • 18
    • 48
    • 16
    • 49
    • 19
    • 50
    • 18
    • 51
    • 16
    • 51
    • 18
    • 54
    • 19
    • 68
    • 20
    • 72
20
30
40
50
60
70
80
Temperature (°C)
  • Idle
  • Load
LGA775 delta T
  • OCZ Vendetta 2
  • Noctua NH-C12P (high speed)
  • Akasa Nero
    • 17
    • 38
    • 17
    • 38
    • 16
    • 40
    • 19
    • 42
    • 19
    • 42
    • 17
    • 43
    • 21
    • 44
    • 20
    • 49
    • 21
    • 49
    • 18
    • 50
    • 24
    • 56
    • 25
    • 67
20
30
40
50
60
70
delta T (°C) (lower is better)
  • Idle
  • Load
Socket AM2+ delta T
  • OCZ Vendetta 2
  • Akasa Nero
  • AMD reference cooler
    • 14
    • 35
    • 14
    • 35
    • 15
    • 37
    • 15
    • 37
    • 15
    • 37
    • 15
    • 37
    • 16
    • 39
    • 19
    • 40
    • 19
    • 41
    • 17
    • 43
    • 25
    • 46
    • 22
    • 46
20
30
40
50
  • Idle
  • Load
To see what these results means, please read the Performance Analysis section
