In Win 904 Review
Written by Antony Leather
January 23, 2014 | 14:16
Tags: #glass-case #in-win-tou #water-cooling
Companies: #in-win
In Win 904 Review - Cooling Performance
In Win 904 Review In Win 904 Review - Cooling PerformanceOur test kit includes an ATI Radeon HD 5870 1GB graphics card and an Intel Core i7-870 CPU, which has been overclocked from 2.93GHz to 3.4GHz using a vcore of 1.305V and a CPU PLL of 1.9V.
This is a modest overclock, but our test kit will spend most of its life under high load, so pushing it too far isn't in anybody's interests. More importantly, some poorer-performing cases push the CPU temperature to above 80°C, so even this overclock will prove to be too much for some cases.
The CPU is cooled by a Gelid Tranquillo CPU cooler with a Noctua NF-S12B ULN 120mm fan. The NF-S12B ULN is a low-airflow fan, so it will highlight cases with poor cooling for the CPU. We also locked the fan speed on the graphics card to 30 per cent to prevent the automatic speed control interfering with the results.
We record the temperature of the CPU using RealTemp, noting the temperature of the hottest core, and used GPU-Z to log the temperature of the graphics card. Having recorded the ambient temperature in front of the main air intake of each case, we're then able to calculate the delta T - the difference between the ambient temperature of our lab and the temperature of the hardware. To load the system, we use a combination of the Unigine Heaven benchmark and the Small FFT test in Prime 95.
  • CPU: Intel Core i7-870 CPU overclocked to 3.4GHz
  • Graphics card: ATI Radeon HD 5870 1GB
  • Motherboard: Biostar TPower I55
  • RAM: 2 x 2GB OCZ 1,866MHz DDR3
  • SSD: Corsair Force GT 60GB
  • Hard drive: 160GB Seagate Barracuda 7200.9
  • Heatsink: Gelid Tranquillo with a Noctua NF-S12B ULN fan
  • Power supply: Antec Signature SG-650
**As our test cooler was unable to fit in the 904 without the side panel being slightly ajar, we used a trick we've employed a few times before and sealed the gap with tape to obtain more representative results. It should be stressed though, that using the 904 with the Gelid Tranquillo Rev.2 is not possible due to the CPU cooler height limit of 145mm. However, seeing as you could potentially use a higher-performing all-in-one liquid cooler, we didn't see this as painting in the 904 in a favourable light as you're not limited to using just low-profile air coolers.**
Case performance - CPU Delta T
Arranged by CPU Delta T
  • SilverStone Fortress FT04 (max speed)
  • SilverStone Raven RV04 (max speed)
  • SilverStone Fortress FT04 (min speed)
  • SilverStone Raven RV04 (min speed)
  • Fractal Design Core 3000 (max speed)
  • Corsair Carbide Air 540
  • NZXT Phantom 630 (max speed; no HDD cage)
  • Corsair Obsidian 900D
  • NZXT Phantom 820 (max speed)
  • Chieftec DX-02B (max speed)
  • Fractal Design Arc Midi R2 (max speed; no HDD cage)
  • In Win Tou (max speed)
  • Corsair Obsidian 750D
  • Corsair Graphite 230T
  • Fractal Design Define R4 (max speed; no HDD cage)
  • Phanteks Enthoo Primo
  • Chieftec DX-02B (min speed)
  • Fractal Design Define XL R2 (max speed; no HDD cage)
  • Fractal Design Core 3000 (min speed)
  • NZXT Phantom 630 (min speed)
  • NZXT Source 530
  • Corsair Carbide 330R
  • NZXT Phantom 820 (min speed)
  • Xigmatek Midgard II (max speed; no HDD cage)
  • In Win Tou (min speed)
  • In-Win 904 (Zalman ZM-F2 92mm + Noctua NF-A15 140mm)
  • NZXT H630
  • In-Win G7 (max speed)
  • Nanoxia Deep Silence 2 (max speed)
  • Fractal Design Arc Midi R2 (min speed)
  • Nanoxia Deep Silence 1 (max speed; ventilated)
  • Fractal Design Define R4 (min speed)
  • Cooltek Antiphon (max speed)
  • Fractal Design Define XL R2 (min speed)
  • NZXT H230
  • Xigmatek Midgard II (min speed)
  • BitFenix Ronin
  • In-Win G7 (min speed)
  • Nanoxia Deep Silence 1 (min speed)
  • Nanoxia Deep Silence 2 (min speed)
  • In-Win 904 (no fans)
  • Cooltek Antiphon (min speed)
    • 40
    • 44
    • 42
    • 46
    • 46
    • 49
    • 46
    • 50
    • 47
    • 47
    • 48
    • 47
    • 48
    • 48
    • 48
    • 49
    • 48
    • 49
    • 49
    • 45
    • 49
    • 45
    • 49
    • 46
    • 49
    • 47
    • 49
    • 48
    • 49
    • 49
    • 49
    • 49
    • 50
    • 46
    • 50
    • 47
    • 51
    • 49
    • 52
    • 51
    • 52
    • 51
    • 52
    • 52
    • 52
    • 52
    • 53
    • 46
    • 53
    • 49
    • 54
    • 49
    • 54
    • 50
    • 54
    • 50
    • 55
    • 49
    • 55
    • 50
    • 56
    • 51
    • 56
    • 55
    • 57
    • 52
    • 58
    • 53
    • 58
    • 53
    • 58
    • 53
    • 58
    • 54
    • 60
    • 53
    • 63
    • 55
    • 64
    • 54
    • 67
    • 60
    • 71
    • 59
20
30
40
50
60
70
°C, lower is better
  • CPU Delta T
  • GPU Delta T
Case performance - GPU Delta T
Arranged by GPU Delta T
  • NZXT H630
  • NZXT Source 530
  • NZXT H230
  • BitFenix Ronin
    • 40
    • 44
    • 49
    • 45
    • 49
    • 45
    • 42
    • 46
    • 49
    • 46
    • 50
    • 46
    • 53
    • 46
    • 47
    • 47
    • 48
    • 47
    • 49
    • 47
    • 50
    • 47
    • 48
    • 48
    • 49
    • 48
    • 46
    • 49
    • 48
    • 49
    • 48
    • 49
    • 49
    • 49
    • 49
    • 49
    • 51
    • 49
    • 53
    • 49
    • 54
    • 49
    • 55
    • 49
    • 46
    • 50
    • 54
    • 50
    • 54
    • 50
    • 55
    • 50
    • 52
    • 51
    • 52
    • 51
    • 56
    • 51
    • 52
    • 52
    • 52
    • 52
    • 57
    • 52
    • 58
    • 53
    • 58
    • 53
    • 58
    • 53
    • 60
    • 53
    • 58
    • 54
    • 64
    • 54
    • 56
    • 55
    • 63
    • 55
    • 71
    • 59
    • 67
    • 60
20
30
40
50
60
70
°C, lower is better
  • CPU Delta T
  • GPU Delta T
Read our performance analysis on the next page.
