AMD's latest 45nm CPU apparently has a large range of temperature operation, and overclocks extremely well.
In a ravenously positive post on Theo Valich's blog, formerly of Inquirer and TGDaily fame, he claims that AMD has worked specifically with extreme overclockers for the first time in years to achieve a 45nm design that is claimed to work flawlessly from -200C to +100C!
AMD has tweaked the on-die sensor to not lock the part when below zero and AMD techies have apparently worked around cold bugs in the new K10.5 architecture.
Apparently a with a good aircooled heatsink "
4.0 GHz is a given on almost every Black Edition CPU that will hit the stores starting January 8, 2009." Watercooling is then claimed to hit 4.5GHz+ and extreme cooling has hit 6GHz in AMD, claims Theo.
Phenom II will launch as part of the new "Dragon" platform in January, along with the 790GX/FX northbridges and SB750 southbridge that includes the new ACC (Advanced Clock Calibration) function. This ACC function is apparently crucial to these overclocking escapades though, effectively making those who own boards with SB600 southbridges or Nvidia chipsets unable to achieve such levels of performance.
We approached Nvidia and asked if future Nvidia MCPs will also feature ACC and it confirmed that it's not an exclusive AMD technology and Nvidia products will feature it. This will enable better choice for the consumer, rather than the one horse race Intel is currently having.
Theo also claims AMD's latest AM3 Phenom II CPUs generate 16GB/s from dual channel DDR3 1,333MHz. While this is clearly less than Intel's triple channel malarkey with Core i7, we've seen in our initial Core i7 review it does little to further performance over dual channel.
The advantage Intel has is a higher integrated memory controller clock and faster core-uncore access over AMD. We can only hope AMD improves this internal latency with K10.5.
Finally, if a Phenom II 940 Black Edition (this is AM2+ however) is "
40 percent of the amount you have to shell out for Core i7 Extreme 965," this could be perceived as good value. However, 40 percent of ~£875 = £350, 35 percent
more than the very popular Core i7 920 that also hits 4GHz and is just £260. When we consider the platform cost though - AM2+ uses far cheaper DDR2, and AMD motherboards are generally a fraction of the price of the current Intel X58 boards out there, so it could all work out remarkably well balanced. The only final consideration is
performance.
Does the possibility of vast overclocks perk your interest? Or will you just be left all excited over nothing like with current Phenoms? Let us know
in the forums.
37 Comments
Discuss in the forums ReplyAll these numbers sound nice, but I've not seen any hard evidence to back them up, yet.
"Let battle commence."
I think it's best to wait... don't want to get too excited at this point, otherwise we'll all get caught with weiner in hand like we did when Phenom launched. :)
I don't remember the exact temperatures, but I know it's true for BJT devices. It may not be so for MOS devices. I'l try and look them up at work tomorrow.
Well if that was the case, there would be no extreme OC with LN2 action ;)
True enough.
That said, I'm not overly disappointed in the performance of my Phenom, but hey. It still wasn't what was promised.
BJT devices do indeed degrade in performance at cryogenic temperatures. However, MOS devices apparently improve, so never mind.
Not so. Even when using LN2, the chip does not entirely reach the temperature of the LN2. You have temperature differentials across whatever mechanism you are using to transfer head from the chip's die to the LN.
Yes true but nitrogen liquifies at -180C, so the chances of hitting -100 are high when you've got a big copper blob firmly bolted to a lapped CPU.
EDIT: Well Tim applies real world to my Chemistry degree :P
When I think of Partridge, I hear "AAGHGGH! It's hotter than the sun!" lets hope they get the TDP down!
I find the i7 platfrom VERY expensive. £260 for an entry (yet very powerful) processor ? When the e6750 (now e8400 etc) was all the rage, I didnt pay anywhere near £260 for it. Nor did I spend >£200 on a motherboard either. Then there is DDR3 (6GB = £200) . If an AMD platform costs less overall and is within spitting distance of Intel... then I would definitely buy it.
Could be speaking utter pants but its just a random factoid (or is it a fictionoid? :D) that is floating about in my head.
Anyway, I'm keen to see how well this latest round of CPUs from AMD perform.
I like the idea of them actually listening to what people (well, OCers anyway) want. :)
In other words, is it underpowered?
Umm... yes, but nowhere nearly as warm as the temperatures obtained by liquid Nitrogen. The highest temperature superconductors still only obtain that state at temperatures around -220C.
Anyhow the Phenom II for AM2+ is certainly on my list to upgrade too, I have the 9950BE on ASUS latest board and Im loving it so I cant wait to get my hands on the new 45 ^__^
Fixed, in anticipation.
P
So is there any AMD dual cores that can overclock really good? My AMD 6000+ is at 3.1ghz or so. It does not OC very well. Not much more than 3.2 and its not stable at ALL.
Also it mentions of needing newer chipsets and such. I've got an MSI K9A2 Platinum with the 790FX chipset. Compatible with these new CPU's?
My Q9450 is stable at 3.52, but not an inch higher.
I have some super sweet aircooling tools, and will be happy if i can overclock as far as thermals will aloow rather than as far as the chip design allows...
4GHz would be great, and if i can keep my DDR2 Dominators, then even better. ;-)
Quite. But AMD isn't exactly charging the earth, unlike Intel, for its current range of BEs. It remains to be seen what Phenom IIs will offer in terms of HTT overhead though
Also one thing im amazed people and especially tech sites didn't pick up on was something i noticed in those leaked slides showing the models and thier names and TDP etc, im posting from my phone so i can't link the slides but if you go find them and look you will notice that for one of the phenoms thats clocked at like 2.8 or 3.0ghz that will be released as both an AM3 and AM2+ version the AM2+ version has a TDP of 125w while the AM3 has a TDP of 95 watts of the exact same clock speed
If thats true im honestly wondering just how well it'll OC with the thermals lowered so much!
It also makes me wonder what will happen once AMD's 45nm process matures if pre production silicon clocks this crazy already.. Im not the most knowledgeable when it comes down to the processes but once iup been optimized etc and a few stepping's down the track won't the TDP drop and other enhancements mean that extreme clockers might be able to hit or pass 7ghz (assuming this current early sample hit 6.3 on liquid nitrogen as reported) and we at home might be able to hit 4+ stable 24/7 on either good air or 5+ on good water cooling? Or have i totally lost the plot here haha
If that was the case however the other processor should have a different TDP as well but they do not, the 3.0 version is still 125 on both platforms while the 2.8 is the one that's TDP changes but either way it makes you think what the over clocking differences would be between the two versions!
Anyhow, as an AMD man I am terribly excited by this and looking forward to january 8.
