MSI watercools its GTX 280 with HydroGen
HydroGen, now with more graphics and less motherboard
This is one for you watercoolers - MSI has launched its latest GeForce GTX 280 with a funky HydroGen waterblock. The "N200 series" features a 700MHz core clock that MSI claims is one of the highest core clocks out there at a 17 percent improvement over stock.
The HydroGen block also sports a 10°C drop compared to the stock cooler but appears not to include the memory with its water coverage. Instead it relies on just a simple copper plate to conduct the heat to the water channels over the large core - much like the Danger Den block used on BFG Tech's GeForce GTX 280 H2OC.
MSI also states that it fits in a single slot now, but the PCI plate is clearly dual slot, unlike the BFG card, whose backplate has been changed to a single slot one. You lose the LED, but honestly - if you're competent enough to use watercooling you don't need to be told how to plug a graphics card in.
In the past, MSI's HydroGen was simply a concept as part of a potential watercooled X38 motherboard - we were first on the scene last year with that one. However, MSI couldn't make it into mass production back then even despite the superior design to other market leaders - this time though, around it seems to have made the big time.
We will be putting both up against each other in a head-to-head soon! Fancy grabbing yourself a watercooled GeForce GTX 280 without killing your warranty? Let us know your thoughts in the forums.
MSI watercools its GTX 280 with HydroGen MSI Watercools its GTX 280 with HydroGen
Fancy something a little different? MSI has called on its German buddies to watercool and overclock its GTX280 with a new HydroGen product.
http://www.bit-tech.net/news/hardware/2008/09/03/msi-watercools-its-gtx-280-with-hydrogen/1
