Will you be overclocking a P45 mobo? READ THIS!
Overclocking Intel's P45 is said to be more complex than it has been on previous boards - you're going to need to do a lot of specialist fine tuning.
After spending time today talking in depth to a couple of MSI's P45 engineers and considerably more to Tony Leach from OCZ Technology, who spends a lot of time QAing BIOSes for companies like Asus, DFI and MSI, it looks like overclocking is going to become an increasingly more complicated art with the release of Intel's P45 chipset, as it mirrors many of the tweaks the current high-end X48 chipset offers.
Overclocking has been progressively getting more difficult since the 975X chipset was introduced, but it wasn't until more recently with P965 and P35 that more advanced options have been released by Intel as the antiquated front side bus runs out of steam.
If you want to buy and overclock on an Intel P45 board (or X48, X38 and P35 for that matter), Leach believes that you must learn how to use:
  • GTL Reference Voltages
  • CPU VTT and its relation to GTLs
  • Clock Skews
  • CPU PLL Voltages
This is because we’ve reached such a stage with the front side bus that the frequencies are getting easily out of sync. You can’t just throw voltage at things any more – that will only get you so far. That isn't to say that voltage overclocking won't work - it will - there's just other factors you will see in BIOS' that are worth learning about.
It’s a case of spending a lot of time increasing the CPU VTT (not over 1.35V – you’ll kill the CPU) and CPU PLL (not over 1.7V, because again you'll kill your CPU) and tweaking the GTL Reference voltages for the CPU and North bridge to be around 61-63 percent of VTT for 45nm CPUs and 67 percent for 65nm.
This is particularly noteworthy with quad-core processors because, if you’re finding two cores drop off under Prime95 load, it’s probably down to the fact that the two CPU dies are not identical and while core one and four can hit the FSB you’ve set, the other pair of cores are having trouble. Tweaking the GTL can sometimes give them better stability.
Leach even went as far as to say you’ve got to find points on the board and check the actual voltages with a multimeter, because we’re talking some extremely minute changes and if there are elements of vDrop from the board or vDroop when the CPU loads the BIOS can be inaccurate.
Next, it's strongly suggested that you also play with the clock skews – we know MSI and Asus will have these on their P45 boards, Asus has them on its current X38 and X48 boards, while both DFI and Gigabyte also have them on their X48 boards. Basically as the data has to jump from the front side bus domain to the memory domain this window becomes smaller and prone to more jitter, the faster you increase either the front side bus or memory frequencies and timings. By adjusting the skew you can realign these clock signals and suddenly stability should return again – a good board will have less jitter in its signal generation and finer skew adjustments than one that's not as good.
The kicker that this is a completely blind art – you’ve quite literally got to sit there for hours and tweak the nuts off the board trying combinations of GTL and Skew settings until you find something that works. You can calculate some of it, like the GTLs, but throwing all the elements in a pot will still require a considerable degree of discovery. However, as soon as you change the front side bus, memory timings, the CPU (no two CPUs are identical, even if you buy a “Q6600 G0”), the memory sticks (there are different tolerances between batches of the same product, never mind different products!), update the BIOS, or even if you’re using the same board as someone else there’s no guarantee that one set of settings will work on another board.
Addendum 14th May 2008: This is not to say you won't get anywhere with just a quick splash and dash, you certainly will, but by learning the new options available and using less voltage - so therefore it gives less heat - you can get the same effect as the brute force method. By combining the two, you can go like a Duracell Bunny: even further, for longer. Speaking to Asus product managers today, they again reaffirmed that just 1.25-1.3V on the northbridge and playing with the CPU VTT and NB/CPU GTL factors can offer a whole more world of performance margins, especially if you are considering DDR3.
So there you have it, prepare to invest in some serious time if you’re upgrading and want to aim for that serious overclock. With this in mind, is there even any point in review sites “reviewing” overclocking any more, since it's unlikely that the end user will be able to replicate it because of equipment diversity? Let us know your thoughts in the forums.
We've got some important information you should read if you're thinking about buying a P45 motherboard and overclocking it.
http://www.bit-tech.net/news/hardware/2008/05/12/will-you-overclock-intel-s-p45/1
