Corsair to use DHX cooling on all XMS2 modules
Corsair has decided to disband its popular “flashy LED” XMS2 Pro-series modules in favour of moving to the newer, and more efficient, DHX cooling solution used on its high-end Dominator memory modules.
Instead of being coloured black like the ones on the Dominator modules, Corsair has decided to keep the silver/metallic colour scheme used on the Pro-series heatspreaders on the new XMS2 modules.
DHX cooling uses technology that has more in common with a conventional heatsink design than it does with a heatspreader and thus Corsair refers to them as heatsinks. The design draws heat from both the DRAM chips themselves and also the ground plane of the PCB to ensure the modules are kept as cool as possible. This is arguably a good thing for the end user, and it will also mean that most of Corsair’s DDR2 memory modules can be speed binned together.
In the past, the company has had to speed bin for XMS2, XMS2-Pro and XMS2-DHX PCB designs, all of which were different. This meant that the company almost stopped producing new XMS2-Pro modules and it has also cut back on standard XMS2 modules too in favour of expanding its Dominator memory series.
Company representatives told us that the release date for the new XMS2 modules is not set in stone yet, but you can be sure that there will be availability as soon as they have been announced. Pricing should also be a little lower than the Dominator modules, too.
Quote Paradigm Shifter 15th March 2007, 18:31
Hm...
This means if I want any of the Pro's I should try to find them ASAP, I guess... (I always found the LEDs useful for seeing if a program actually was stuck solid, or whether it was still working...)
Quote Tyinsar 15th March 2007, 20:21
hmm, I never considered that use for the LEDs but otherwise I like the new plan (I'd prefer the only visible part of my computer to be the parts I directly interface with: monitor, mouse, keyboard - and If I could stealth those and retain the functionality I'd do that too.)
Quote rowin4kicks 15th March 2007, 20:44
never really liked the led displays anyways, they just look tacky to be honest, and when trying to create a minamilst looking case they can just ruin it
(although cant you take them off?)
Quote Skill3d 15th March 2007, 20:55
these are multi functional, cooling ram and fix bad hair days... damn they look like combs :)
