AMD announces DTX standard for SFF PCs
Image courtesy of the Inq.
AMD today announced the development of its DTX "open standard" for Small Form Factor (SFF) devices, based around AMD Athlon 64 CPUs. It's a move to promote AMD into a smaller, quieter PC, whilst building off of the current ATX spec.
It's primarily designed for OEMs, ODMs, and component vendors, so we should see everyone from Dell to your favourite PC motherboard manufacturer making motherboards and PCs based on the DTX specification.
However, manufacturers like Shuttle with its XPC range already do well in the SFF arena and its designs are considerably smaller than the DTX prototype shown. Also, it could be argued what's wrong with the current micro ATX spec?
The Introduction of new motherboard specifications by Intel (BTX, uBTX) in the past has proved unsuccessful. Having being built around the ATX specification, however, the DTX boards should fit into a standard ATX case which means a possible upgrade for that new MCE chassis you just invested in.
BTX was bad for AMD because it sat the CPU too far away from the memory slots, because the northbridge is integrated onto the Athlon 64's die. This was a cunning move by Intel to force AMD into an awkward position. Luckily, in the interest of consumer choice and competition BTX fell flat on its face. With DTX, the CPU is right next to the memory slots and the northbridge is on the other side of the CPU socket, pretty much as far away as possible. It's now extremely unlikely you will see an Intel based DTX board.
Considering the recent anti-trust case brought by AMD on Intel, this is incredibly ironic. It's an "open standard", so AMD reap no royalties from using it, but the competition can't use it anyway, so they are still the only ones making money from it.
Will AMD get anywhere with DTX considering how BTX turned out for Intel? The microATX market is small, at best, and the best SFF manufacturers (Shuttle) tend to go their own route with proprietary solutions.
You can see bigger pictures at the Inquirer.
Quote Techno-Dann 10th January 2007, 16:36
It's BTX, but set up to favor AMD rather than Intel. And minus the integrated-cooling design.
My prediction is it will go the same way BTX has: There will be a few motherboards released, some big manufacturers will make a few computers based on it, but it won't take over from ATX.
Quote Mankz 10th January 2007, 16:50
it might work if people make a half-decent PSU / case to fit....
Quote DougEdey 10th January 2007, 16:52
Surely AMD are there already with the EE series? The microATX boards are there aswell, and I cant tell any differences.
Quote mikeuk2004 10th January 2007, 17:34
Nice one AMD. Get that nasty northbridge away, far away i tell you.
Who needs intel with this and a AMD CPU and and ATI card. Your sorted. Bye Intel
Quote DeX 10th January 2007, 17:41
What are the board's dimensions?
Quote LoneArchon 10th January 2007, 19:25
DTX 200mm x 244mm
Mini-DTX 200mm x 170mm
I can see Mini-DTX killing itx which is 170mm x 170mm if they price it in the range of mATX. I know there is AMD based itx board but they very expensive for what they are. The socket 754 is $300 http://www.newegg.com/Product/Product.asp?Item=N82E16813170012&ATT=13-170-012&CMP=OTC-Froogle
Quote DXR_13KE 10th January 2007, 23:07
BTX failure was predictable.... and this format will not be that successful to.....
Quote leexgx 10th January 2007, 23:11
i only ever seen Dell ever use BTX
it uses ATX norm headers for fiting the mobo to the case
so the mobo will still work in norm ATX cases
makeing motherboards for ITX as its an small part of computer sales so its hard to sell an ITX mobo
DTX as it works in ATX and DTX if realy cheap motheroards are made thay mite get used alot more
Quote Gravemind123 11th January 2007, 00:24
I think this will go the way of BTX. The mini-DTX might be useful if they make a cheap one, since ITX is so expensive. There really is no practical reason for picking up a DTX board if you can't get one for less then an ATX/mATX board of equal quality.
Quote Generic42 11th January 2007, 00:47
If this turns out to be mATX price I'd pick one up (this also assuming I had money).
The industry will never move forward unless one side starts trying. I'm not too happy with AMD/Intel going at each other's throats, I'd have hoped it'd at least be okay with Intel chips rather than putting them down so hard. But oh well, looks pretty good size-wise and is hopefully cheap. If this can be well priced it will make it, but not be a big hit, imo.
