Sennheiser IE - Professional In-Ear Monitors
December 18, 2008 | 14:52
Companies: #sennheiser
Sennheiser challenge the High-end in-ear market
- Sennheiser's first high-end ear-canal consumer headphones
- Based on Sennheiser legendary in-ear stage monitors
- Noise Isolation and stunning sound
Sennheiser IE 6: Hi-Fi with Enhanced bass £119.99
Sennheiser IE 7: Classic Hi-Fi Balanced Sound £169.99
Sennheiser IE 8: The best. For enthusiasts £249.99
Sennheiser are one of the world's leading suppliers of in-ear monitor systems for musician and stage use. These are basically very high quality and accurate ear-canal headphones.
The new IE Professional monitor series from Sennheiser, brings to consumers the same high-end, accurate Sennheiser pro-grade
audio that musicians and performers have trusted for years.
- High-end, accurate, pro-grade audio
- Advanced technology single-driver eliminates the distortions found in multiple-driver designs
- Robust construction
- Kevlar Cables
- Metal carry cases
- Two year guarantee
Key design points for the IE range vs competition. Why Sennheiser opted for single-driver dynamic designs
- Wide frequency range
- Better sound quality
- Less distortion overall
- Less distortion at higher volumes
- High reliability
- Small size vs Bulbous
It has become a myth that multiple driver designs are necessary for high-end in-ear headphones. Not True! The reality is that a well-engineered single drive-unit can cover the full audible frequency range and beyond, while outperforming multi-way designs and eliminating the many phase and distortion problems introduced by crossovers and multiple drive units. Highly-advanced single-driver-design The IE series use advanced technology dynamic transducers that cover the entire frequency range with one drive-unit - even
tricky basslines and thunderous sound effects separate themselves clearly in the mix. This design eliminates the distortion from crossovers and multiple drivers, that detracts from the integrity of the original source material.
Multiple ear-adapters
Depending on model, between six and twelve different types and sizes of ear-adapter are supplied to provide a custom fit and seal out
ambient noise. New double flanged ear adapters, offer personalised fit and noise isolation Up to 26db isolation from external noise
Good isolation further enhances precise audio reproduction; the top-of-the-range IE 8 can reach up to 26 dB of noise attenuation. The other models up to 20 dB.
Robust professional design
All the models in the IE range feature robust and functional design. Each headphone is equipped with a case, small cleaning tool
and a cable clip. All are iPhone compatible. Very high-efficiency on all models increases battery life on portable players
Everything compatible
Use with MP3, iPod, iPhone, DVD, CD players, mobile phones (3.5 mm jack plug) Use for pro-monitoring with 24-bit pocket recorders
Silent Kevlar Cables - reinforced for strength The IE series use a thin and flexible cable with very low mechanical noise. Nonetheless, this cable comes with integrated Kevlar™ fibres for strength and offers the high quality and reliability expected from professional products.
Ear clips supplied for optional use
In order to enhance the wearing comfort, Sennheiser have developed detachable ear clips with integrated metal wires that can be adjusted to the user’s ears.
THREE MODELS
Sennheiser IE 8: For enthusiasts £249.99
Miniature High-end in-ear-canal monitor headphone Based on Sennheiser legendary in-ear stage monitors Compare with the most expensive competition
- Unique custom tuning for sound
- Supplied with twelve different ear adapters
- High-fidelity noise-isolating ear-canal phones with unique
sound tuning functionality and interchangeable cable
- Dynamic speaker systems with powerful neodymium magnets
ensure outstanding sonic accuracy and clarity
- Excellent attenuation of ambient noise (95 %, up to 26 dB)
- Extremely durable housing and rugged, interchangeable cable
- Soft 'Silent' cables strengthened with Kevlar
- Unique, manual frequency response tuning functionality
- Sleek ergonomic design of ear-canal phones and various types
and sizes (S/M/L) of ear-fit rings allow for the best custom fit
- Compatible with MP3, iPod, iPhone, DVD, CD players and
mobile phones (3.5 mm jack plug), and 24-bit pocket recorders
- Package includes: Ergonomic ear-canal phones
- Deluxe protective case with dry salt pads
- Extended Ear-fit-set (S/M/L) Four types in three sizes
- Sound adjustment and cleaning tools
- Cable clip
Frequency response: 10 to 20,000 Hz
Customise the frequency response to listening preferences
Attenuation up to 26 dB,
The IE8 bass tuning functionality is patented-applied for. It works by adjusting a screw to modify the diameter of a pipe that allows
more or less air to exit a cavity behind the transducer. If more air can get out (open), the diaphragm can swing further (less resistance from compressed air) and can therefore generate more bass. And vice versa. Sennheiser IE 7: Classic Balanced Sound £169.99
Supplied with nine different ear adapters
deliver audio reproduction that is balanced, precise and true-to-life
- Excellent attenuation of ambient noise (90 %, up to 20 dB)
- Extremely durable housing and rugged, high-performance cable
- Ear-fit-set (S/M/L) Three types in three sizes
- Cleaning tool
- Cable clip
Frequency response: 10 to 19,000 Hz Attenuation up to 20 dB Balanced, natural sound. Particular importance has been paid to achieving smooth extended treble Sennheiser IE 6: Enhanced bass £119.99
Supplied with six different ear adapters
deliver greater sound definition and enhanced bass
- Extremely durable housing and rugged cable
- Sleek ergonomic design of ear-canal phones and various sizes
- Ear-fit-set (S/M/L) Two types in three sizes
- Cleaning tool
- Cable clip
Frequency response: 10 to 18,000 Hz Attenuation up to 20 dB,
The IE 6 offers deep, luscious bass for listeners of contemporary rock or dance music, the silver and black ear-canal headphones take this very accurate and defined sound right into your ear.
AUTHORISED STOCKISTS info from - Sennheiser Web Search
About Sennheiser
Established in 1945 in Wedemark, Germany, Sennheiser is the acknowledged world leader in headphone-transducer and microphone technology, RF-wireless and infrared sound transmission and, most recently, the development of active noise-cancellation. Sennheiser’s products and technologies support worldwide the aviation, telecommunications and professional recording industries, as well as the personal listening needs of consumers everywhere.
