• powered directly from your notebook
• can be used as a simple notebook rest with fans switched off
• stylish aluminium top panel enhances heat dissipation
• two USB ports enables a second low-power device (e.g. mouse)
• ultra-quiet fans with on/off switch
• lightweight construction for easy portability
• suitable for 15.4” widescreen or below
Specification
• on/off fan switch
• dimension : 334 x 275 x 36 mm
• weight : 720g
• connectors : two USB type A
• cable : 600 mm USB cable
• two fans 70 x 70 x 15 mm
• fan speed : 1500 RPM
• rated voltage : DC 5V
• really light and portable
