Join us online tonight. Homework? Food? Family Commitments? Pffff forget it!
Enjoy playing the very addictive
Team Fortress 2 from Valve? We've
teamed up with
Intel to reignite our
Octo-core (dual quad-core Xeon) gaming server to provide some crazy online FPS gaming action for you all.
Join our
bit-tech Steam group
here and check future event times for our next get together. The first of which is incidentally tonight at 8pm (GMT) if you can make it.
Or, you could just add:
194.74.152.172:27015 to your favourites!
Join early, because places are likely to go faster than hot cakes wrapped in £50 notes.
So are you going to join us later? Let us know,
in the forums!
MEEEDDDIIIICCC!
click here for the maps - http://ride-the-fire.co.uk/downloads.php
or
http://ride-the-fire.co.uk/files/TF2%20maps/cp_mappack.zip
http://ride-the-fire.co.uk/files/TF2%20maps/ctf_mappack.zip.
He's talking about the new maps.
EDIT : only 20 slots ? Come on, we know you can bump it to 24 !
cp_castle and cp_wolf are cool maps which should be added !
8pm is an arsey time cos im usually eating around then (and most of the rest of the day but thats an actual proper meal)
I cant even find out if TF2 (client) is multicore, let alone the server side
We'll be running a UT3 server once available FYI peoples
As well has tf2? you got the virtualisation working?
Same thing for me as well, I'm utter shite at the moment, but I'll check out the server today after work ;)
clicky
I'm going to look at getting the http downloads set up and then will chuck up some custom maps - have to do some work first though ;)
short and sweet, thanks Archangel ;)
Unfortunately, apparently "this server is using an older protocol than your client" - so you won't be able to see my uber-leet skillz...
http://steamcommunity.com/groups/ocau
team anandtech hasn't seen growth for a month because of no promotion :!
http://steamcommunity.com/groups/anandtech
Team OCAU vs bit-tech now thats a match i want to see : ) overclockers vs bits !
I get enough stress at work, let alone gaming too :P
I hate hydro! Lazy towns pretty good if you can rely on your team, then again all the maps fall apart if your team is pants
cl_updaterate 100
cl_cmdrate 100
might help
NO STOP IT!
I did that :o
Maybe I should add it to the MOTD <chuckles>
On a separate note: any more custom maps we should put on?
where do i put the other stuff to?
We're also setting up a UT3 server for Mondays, Wednesday or Fridays as well.
There's a choice? I stopped playing after kill 7 and haven't been compelled to go back to finish...
Of course I did spend 2 hours trying to get UT3 to work last night....
thanks for showing up, Benny
Basically, as it currently stands I can't change it.
Tried that doesnt support UT3 yet. Trying gamespy but there doesn't seem to be a connect via IP address thing either and I cannot find anything under bit or trusted when doing a name search :(
As for spawn times on tf2 i thought this was an admin controlled variable. some servers I have been on even have instant respawn just like original tfc
If not, x-fire pwns :)
Edit: Just Downloaded X-Fire and I can't seem to add the Bit UT3 server to the list. This is getting frustrating...
Slightly reassuring that im not the only one, I managed to add it as a favourite on gamespy but it was blank had a ping of 9999 so I could assume it isn't actually running!
F10 to open console and then type "open 194.74.152.172:7777" without the quotes.
F10 in UT3 does open the console [shrugs]
Go to Servers tab
Right click on "Favorites"
Click "Add Custom IP to Favorites"
Select UT3 (or demo if that's the case) from the dropdown
Enter the IP (maybe the port, not sure with UT3 ...)
Click ok and double click your new entry to launch UT3 and connect to the server
I tried that Unreal Tournament 3 isn't there. I think its safe to assume that Bindi is correct and it isn't running yet!
To connect to the BT server just open the console and type open 194.74.152.172:7777 and you'll get into the BT server
Wrong assumption. I had it running on Friday but I can't work out why it isn't in the server list - all the info my end indicates it should be, bu tI have to join manually.
I am enjoying the single player, but I think I'm going to have to replay it again once I get a decent graphics card - going by the screenshots, on a top end system, it should look as Gears does on the 360.
Now I know it shouldn't look *that* good on my 6600, but I would have thought it should look at least look as good as UT2004 did - however, on my system It looks like Doom.
/rant
If the other team hadn't been full i'd have swapped sides and made sure he was burning for the rest of night!
