Scythe Co., Ltd (Tokyo, Japan) announces its original 120mm case fan, "Slip Stream 120mm Case Fan". By seeking the better performance yet not to compromise in the noise level, this Scythe original "Slip Stream 120mm Case Fan" is finally developed by the Scythe engineer to allow the higher airflow by reducing the dimension of the center hub, and this result in the wider surface area of the fan blade. The fan speed is arranged for 5 different rpm (500/800/1200/1600/1900rpm) to meet the demand from wide variety of users in the market. From silent users to power users in the market, you got more choices and airflows no matter which model you choose from! Better airflow than a standard 120mm case fan available in the market, and this gives the obvious benefit to use this case fan!
Below (attached) are graphs showing a comparison of various fans including Scythe Slip Stream
120, Minebea, and Scythe S-FLEX fans
Model Name: Slip Stream 120mm Case Fan
Model #: SY1225SL12SL (500rpm version)
SY1225SL12L (800rpm version)
SY1225SL12M (1200rpm version)
SY1225SL12H (1600rpm version)
SY1225SL12SH (1900rpm version)
Manufacturer: Scythe Co., Ltd. Japan
Dimensions: 120 x 120 x 25mm
Specifications: 7.50dBA / 24.50CFM / DC12V / 0.07A (500rpm version)
10.70dBA / 40.17CFM / DC12V / 0.10A (800rpm version)
24.00dBA / 68.54CFM / DC12V / 0.26A (1200rpm version)
33.00dBA / 88.11CFM / DC12V / 0.41A (1600rpm version)
37.00dBA / 110.31CFM / DC12V / 0.53A (1900rpm version)
Weight: 115g
Connector: 3-pin (3-pin to 4pin adaptor included)
Bearing Type: Sleeve Bearing
MTBF: 30,000 hours
MSRP: 9.80 (USD)
6.50 (EURO) excl. VAT
http://www.scythe-eu.com/en/products/fans/slip-stream-120.html
http://www.scythe-eu.com/en/press-room/press-releases/slip-stream-120.html
