Those sneaky Wolfs will come and take your monies, for you will want to upgrade!
Although it's a hectic life being an IDF hack, shooting from keynote to workshop to face-to-face, I managed to find ten minutes (literally) to catch up with the extremely helpful Intel Digital Home Engineer, Jeremy Saldate, who kindly showed off a demo of Core 2 Duo versus Wolfdale.
All this talk of quad-core
Penryn at 45nm and it's easy to forget its dual-core companion, Wolfdale. It is made using the same 45nm process with the associated optimisations, but only has a 6MB cache (rather than 12MB) and a single dual-core die (rather than the twin dual-core die to create quad-core).
It also has a lower thermal envelope which should allow for much better overclockability compared to Penryn.
Jeremy showed off a real world automated run of the latest Adobe Première Pro optimised for SSE4. Obviously, this gives the Wolfdale a distinct advantage, having the software capable of utilising the new instructions. This is also a carefully selected situation but it's still impressive nonetheless.
The program rendered the video at 14.44 fps on the new Wolfdale dual core CPU, but could only manage 9.77 fps on the current generation Core 2 Duo.
Are you reaching for your wallet already? Or do you feel the need to wait until
bit-tech gets a-hold of one to
really see if it's worth your cash? Let us know
in the forums.
Its Socket 775 I guess, with DDR2 or what?
From what I remember they are pin compatible with Core 2 Duo, so all that should be needed is a BIOS update.....I could be totally off mind you!
There looking pretty good though, will def have to consider when I finally decide to part with my hard earned cash for a new rig.
Were the processors in this demo identically clocked, or was the Wolfdale clocked higer and/or on a 1333 FSB with the Conroe on 1066?
How can you even ask such a silly question?? Naturally we want you to get a few into your hardware testing dungeon, and test it till it sweats :D
Lets start actually writing software that actually takes use of multiple cores!
Sheesh, almost nothing, is multi threaded yet.
You are naturally completely correct, I would say dual core (or dual CPU) is great (yeah you can alt-tab out of games without having to wait 5min), 4+ cores who needs them? (apart from specific server programs made to use multiple cores)
