Image courtesy of the Inq.
AMD today announced the development of its
DTX "open standard" for Small Form Factor (SFF) devices, based around AMD Athlon 64 CPUs. It's a move to promote AMD into a smaller, quieter PC, whilst building off of the current ATX spec.
It's primarily designed for
OEMs, ODMs, and component vendors, so we should see everyone from Dell to your favourite PC motherboard manufacturer making motherboards and PCs based on the DTX specification.
However, manufacturers like Shuttle with its XPC range already do well in the SFF arena and its designs are considerably smaller than the DTX prototype shown. Also, it could be argued what's wrong with the current micro ATX spec?
The Introduction of new motherboard specifications by Intel (BTX, uBTX) in the past has proved unsuccessful. Having being built around the ATX specification, however, the DTX boards should fit into a standard ATX case which means a possible upgrade for that new MCE chassis you just invested in.
BTX was bad for AMD because it sat the CPU too far away from the memory slots, because the northbridge is integrated onto the Athlon 64's die. This was a cunning move by Intel to force AMD into an awkward position. Luckily, in the interest of consumer choice and competition BTX fell flat on its face. With DTX, the CPU is right next to the memory slots and the northbridge is on the other side of the CPU socket, pretty much as far away as possible. It's now extremely unlikely you will see an Intel based DTX board.
Considering the recent anti-trust case brought by AMD on Intel, this is incredibly ironic. It's an "open standard", so AMD reap no royalties from using it, but the competition can't use it anyway, so they are still the only ones making money from it.
Will AMD get anywhere with DTX considering how BTX turned out for Intel? The microATX market is small, at best, and the best SFF manufacturers (Shuttle) tend to go their own route with proprietary solutions.
You can see bigger pictures at
the Inquirer.
My prediction is it will go the same way BTX has: There will be a few motherboards released, some big manufacturers will make a few computers based on it, but it won't take over from ATX.
Who needs intel with this and a AMD CPU and and ATI card. Your sorted. Bye Intel
Mini-DTX 200mm x 170mm
I can see Mini-DTX killing itx which is 170mm x 170mm if they price it in the range of mATX. I know there is AMD based itx board but they very expensive for what they are. The socket 754 is $300 http://www.newegg.com/Product/Product.asp?Item=N82E16813170012&ATT=13-170-012&CMP=OTC-Froogle
it uses ATX norm headers for fiting the mobo to the case
so the mobo will still work in norm ATX cases
makeing motherboards for ITX as its an small part of computer sales so its hard to sell an ITX mobo
DTX as it works in ATX and DTX if realy cheap motheroards are made thay mite get used alot more
The industry will never move forward unless one side starts trying. I'm not too happy with AMD/Intel going at each other's throats, I'd have hoped it'd at least be okay with Intel chips rather than putting them down so hard. But oh well, looks pretty good size-wise and is hopefully cheap. If this can be well priced it will make it, but not be a big hit, imo.
