Onwards and upwards by imersa and Parvum Extreme MbK by kier
Parvum Systems is a relative newcomer to the case scene but its interesting small form factor cases that feature an inverted ATX motherboard mounting and racy acrylic colours have certainly been grabbing some attention in our forums. The company's current S1.0 case has been adapted and used in this project to create Onwards and Upwards, which was finished recently.
May 2013 Bit-tech Modding Update Onwards and upwards by imersa and Parvum Extreme MbK by kier May 2013 Bit-tech Modding Update Onwards and upwards by imersa and Parvum Extreme MbK by kier
It's an absolutely stunning project that really showcases the case's potential - we'll hopefully be looking at Parvum cases soon too, but if you'd like to get the low-down on the company as well as more info on the project, head over to the project log.
Does this guy never stop? Yes, kier is back once again having delved into several projects already this year, and Parvum Extreme is, as you may have guessed, another project that features a Parvum case. This time, the case has had to adapt to kiers obsession with water-cooling hardware and has been vertically extended by essentially adding another on top.
The result is eye candy-filled, water-cooled PC of awesomeness, although we'd expect nothing less from kier, who has also employed some straight acrylic tubing from E22. If you're a water-cooling fan you should definitely check that stuff out and in the mean time you can also see kier's project log here.
In the meantime, head over the page to see more eye-candy.
