H&D2 Ammo Box Shuttles
Written by Dave Williams
February 14, 2005 | 00:00
Tags: #casemod #dave-williams #kustom #macro #spray-paint #stencil #take2
Companies: #ati #corsair #creative #shuttle #western-digital
Once all the main painting was finished, it was time to start dirtying the cases to make them look as if they were being used in service. Several techniques were used in combination to achieve the final effect. Here they are shown individually to demonstrate each method.
H&D2 Ammo Box Shuttles Dirtying down and scratching
H&D2 Ammo Box Shuttles Dirtying down and scratching H&D2 Ammo Box Shuttles Dirtying down and scratching
A technique used on the checker plate (although it was used less so on the plain case) was to paint the case with black acrylic paint and before it dried, it was wiped off using a cloth. This left traces of black paint in any pits and grooves on the case.
A shot of the paint being used on the plain case.
Another dirtying down method consisted of several shades of artists chalks ground into dust by rubbing on sandpaper...
...this dust was then brushed onto the cases particularly into the nooks and crannies. The chalks used are of the dry and not the wax type.
Dust, dust everywhere...
The flash washes it out somewhat, but the effect can be seen here.
The dust was rubbed in and the excess removed with a cloth to leave a grimy looking finish. Unfortunately, the harsh lighting in these pictures tends to wash out the effect.
Close up of the "grime" worked into the seams around the case.
To simulate scratches and bare metal, a technique called "dry brushing" was used. Here the paint is wiped off the brush on to a cloth or paper so only a trace is left leaving the brush almost dry, hence the name. The brush is then dragged over the subject leaving traces of paint on any raised areas. Using a mixture of grey and silver paint a realistic scratched bare metal look can be achieved.
Dry brushing on one of the clasps.
After all the dirtying was complete and dried the cases were given a light coat of satin clear sealer to protect the finish (including the dust).
