Asus M4A89GTD Pro/USB Motherboard Review
March 2, 2010 | 10:21
Tags: #890gx #am3 #comparison #mobo #motherboard #oc #overclock #overclocking #performance #result #review #s-ata #sata-3 #sata-6gbps #sata-iii #sb850
Companies: #amd #asus #test
Crysis
Publisher: Electronic Arts
We tested the game using the 64-bit executable under and DirectX 10 with the 1.21 patch applied. We used a custom time demo recorded on the Harbour map which is more representative of gameplay than the built-in benchmark that renders things much faster than you're going to experience in game.
For our testing, we set all the settings to High. Because of how intense the game is, we tested with 2x anti-aliasing, but with anisotropic filtering disabled, and at a resolution of 1,680 x 1,050. There is currently no support for anisotropic filtering in the game, but you can still force it from the driver control panel.
Crysis
1680x1050 2xAA 0xAF, All High Settings
  • MSI 890GXM-G65
  • Asus M4A89GTD Pro/USB
  • MSI 785GM-E65
    • 21
    • 42
    • 21
    • 40
    • 18
    • 40
20
30
40
Frame rate (fps), higher is better.
  • Minimum FPS
  • Average FPS
Crysis (OC)
  • MSI 890GXM-G65
  • MSI 785GM-E65
    • 26
    • 47
    • 25
    • 46
    • 24
    • 44
20
30
40
50
  • Minimum FPS
  • Average FPS
To see what these graphs mean, read the Results Analysis page.
STALKER: Call of Pripyat
Publisher: bitComposer Games
We ran the full STALKER: Call of Pripyat benchmark, with SSAO set to Low, Tessellation enabled, and Contact Hardening Shadows disabled. We run the game in the Ultra graphical options preset, with the 'Enhan. full dyn. lighting (DX11)' rendering. Of the four runs, we only take the results form the last:
1680x1050 0xAA 0xAF, 'Extreme' DX11, SSAO Low, Tesselation on, Sunshifts Bench
  • MSI 890GXM-G65
  • MSI 785GM-E65
    • 36
    • 52
    • 33
    • 52
    • 32
    • 51
20
30
40
50
  • Minimum FPS
  • Average FPS
STALKER: Call of Pripyat (OC)
  • MSI 890GXM-G65
  • MSI 785GM-E65
    • 35
    • 52
    • 33
    • 51
    • 32
    • 52
20
30
40
50
  • Minimum FPS
  • Average FPS
